Best way to install/remove hubcaps without damaging them? - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 21st, 10, 04:06 PM Thread Starter
Joseph
Just removed the stock mag hubcaps. I have been using a taped off flat blade and a rubber mallet but was wondering if there are better ways of removing and installing hubcaps without denting or scratching them. Anyone have any tips?
cam1967rsss is offline
post #2 of 6 (permalink) Old Dec 21st, 10, 05:36 PM
Re: Best way to install/remove hubcaps without damaging them?
I used the original lug wrench with the tapered end ground flat and wrapped a shop rag or washcloth to protect and pried a little at a time about the circumference until it popped off.
post #3 of 6 (permalink) Old Dec 21st, 10, 05:57 PM
Skip
Skeeter55's Avatar
If i recall corectly... They make a plastic/metal type of
http://www.toolsource.com/center-remover-p-104192.html
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #4 of 6 (permalink) Old Dec 23rd, 10, 02:56 PM Thread Starter
Joseph
Thanks for the tips guys. What about installation? Even though I use a rubber mallet, I get nervous I am going to dent them since it takes a lot of pounding to get them on.
post #5 of 6 (permalink) Old Dec 23rd, 10, 03:19 PM
DjD
DjD's Avatar
Install hubcaps and rally caps by popping at them with the palm of your hand or pinky finger side of your fist... Don't try to pop it all the way on at once, go a little at a time all the way around starting at the valve stem.
...Dennis
DjD is offline
post #6 of 6 (permalink) Old Jan 4th, 11, 07:06 PM
Dan
If you can't get them by hand, then a drum brake adjusting spoon (looks like a bent screwdriver) will do the trick.
62 Corvette (Stock Restoration)
68 RS/SS Camaro, LS7/T56
68 RS Convertible project LS3/480/4L70
2006 Corvette Z06
2011 Corvette GS Convertible
68sixspeed is offline
