Arizona code JJ Rally ? - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 22nd, 11, 12:31 AM Thread Starter
Lex
Lexlas's Avatar
Question Arizona code JJ Rally ?
Can you guys help me with some info on some Rallys i purchased. So i buy these because they were listed as 15x8. I have attatched pictures of the codes on the rally rims. When i measure them i get 16x9. They also have a JJ stamped on the rim. The center rally cap does not fit with the current lug nut bolts i had - my guess is i need new different ones also.
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #2 of 3 (permalink) Old Jan 22nd, 11, 06:03 AM
Wayne
butternutz68's Avatar
Re: Arizona code JJ Rally ?
Looks like factory corvette rims, should be az code next to valve stem hole ,if so they are 15 x 8 measure inside the lip of rim. Also they have a
4 inch backspace which pushes them out a little towards the outer fender.They take a standard lug nut.
work in progress
butternutz68 is offline
post #3 of 3 (permalink) Old Jan 22nd, 11, 08:51 AM
Bryon
bcm66's Avatar
As Wayne stated, check by the valve stem hole on the outside of the wheel for the code. JJ was commonly stamped on the inside of wheels, different sizes, so that won't tell you anything.
If if is stamped 15 x 8 - that is most likely the size. I have never seen them stamped wrong.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
Closed Thread
