15" wheel and tire combo's - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 25th, 11, 06:36 PM Thread Starter
Cody
What is the widest tire and wheel combination in a 15" that you can run on a 68 camaro without tub's? Please include wheel size and backspacing and tire size..thanks If you have pics that would also be much appreciated...
sbc350 is offline
post #2 of 6 (permalink) Old Jan 25th, 11, 06:50 PM
Lex
Lexlas's Avatar
Re: 15" wheel and tire combo's
These are the biggest 15's i've seen. I have attatched a link to 1968 Wheel and Tire Combo's...
https://www.camaros.net/forums/showthread.php?t=153193
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #3 of 6 (permalink) Old Jan 25th, 11, 07:15 PM
Banned
Bethanne
Nashville Beth's Avatar
Cody,
I have 15" rally wheels and I've learned this:
A 275-60-15 will fit if the backspace is perfect. A 255-60-15 is better. You will need a wheel with 4.5" backspace.
NPD sells these.
Nashville Beth is offline
post #4 of 6 (permalink) Old Jan 26th, 11, 08:52 AM
Russ
You also need to take into account width vs. the ride height of the car.
I'm running 225/60's up front on 15x7's with 3.76" BS and they just clear full lock to lock on my car with Hotchkis springs F + R. My front fender lips are 24.75" from center to ground.
In the rear I run 245/60's and could easily go to 255's with the same 15x7's and 3.76" BS, rear fender lip height is 27.25".
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #5 of 6 (permalink) Old Jan 26th, 11, 10:42 AM
Banned
Bethanne
I'm also running 225/60's up front on 15X8 corvette rallys. Haven't driven it in several years so I'm not sure if they rub. If they do I'll switch to the 15X7's.
post #6 of 6 (permalink) Old Jan 26th, 11, 07:12 PM
67 Camaros Rock
Joe Harrison's Avatar
1967 Camaro, rear on a Crager Eliminator 4.5 inch back space 275/60/15 tire (old crappy tire) for fit check. Hotchkiss rear springs. Car is empty no interior, glass or gas tank.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
