15X8 on stock front supension - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 29th, 11, 07:57 AM Thread Starter
Silvio
My question is if anyone has had 15x8 wheels with 4.5 backspacing installed in the front of a stock suspension with disc brakes without tire rubbing. I would like to stay with 15x8 and a good tire size in the front but if there are rubbing issues then I will get 15x7's.
Also what type of tire size was used or recommended in front and back.
Thank you in advance.
1968guppy is offline
post #2 of 2 (permalink) Old Jan 29th, 11, 04:30 PM
Arch Stanton's Avatar
Re: 15X8 on stock front supension
I still have drum brakes,
and I have a 1" Addco front sway bar that looks to be bent slightly different than the stock piece...
I get the tiniest rub from the lip of my Weld ProStars on the sway bar. More like the wheel weight clamp part just barely hits it and I mean barely kisses it at full steer lock. Both sides.
Perhaps if I still had the stock size sway bar, it wouldn't hit it at all, but again, it just barely touches it.
15 x 8 with 4.5 bs.
235/60-15 tire.
Hope that helps........even tough I still have drums up front. Yes, its on my "to do" list of things to change.
Tires don't rub at all.....
- John
Misfit tortured soul. Lone wolf. Unicorn.
'67 V8 Camaro - 12637, 797-Z (Parchment), M-M (Royal Plum), 2M, 3K, 5Y
Arch Stanton is offline
