Rear tire fitment and back space question - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 30th, 11, 12:41 PM Thread Starter
mike chiarito
Ok guys I have done some major searching and cant find any answers.I am about to order some new wheels and tires and want to make sure they will fit.I had a set of weld drag lites front and rear the rears were 8in by 4.5 back space and fronts were 3.5 by 1 5/8 back spaceing.I was wondering if I could fit a 8in rear rim with a 295/55/15 mickey thompson drag radial.Heres where it gets tricky I have seen manny people run the mickey thompson et drag which measures 28.1 inches tall annd has 11.7 section which is buldge to buldge. The drag radial will measure 27.8 inches tall and 12.0 section.Do u think It will fit?I was also thinking of going with 5.5 back spaceing. Fronts I am converting to ls1 brake conversion was hopeing to run 4inch wheels with 2.25 back spaceing.
TEAM CAMARO SS CHICAGO
shadys69 is offline
post #2 of 8 (permalink) Old Jan 30th, 11, 12:49 PM
Trey Burks
Re: Rear tire fitment and back space question
Even with the correct wheels 4.5 you will still need a small 1/2 inch spacer on the rears. I had pro stars on my camaro for a while.
67 RS/SS loaded with options Granada gold AKA Christine
Im a Traditionalist when it comes to Muscle Cars
04 F150 4 door 5.4
If you are on Facebook join the group.restore that first gen camaro dont chop it up.
67goldrsss is offline
post #3 of 8 (permalink) Old Jan 30th, 11, 12:51 PM
Trey Burks
275 60 15's will clear, I dont know if 295s will clear though with out a spacer. I know 275s hit my air shocks.
04 F150 4 door 5.4
post #4 of 8 (permalink) Old Jan 30th, 11, 01:05 PM Thread Starter
mike chiarito
Why do you say I will need a spacer with 4.5 bs?I Curently have welds with 275 60 15s fit like a glove no ishues.
I figured mabey to go with the 5.5 bs just to move the wheel in a little and possibly use a small spacer if needed to get it perfect.
shadys69 is offline
post #5 of 8 (permalink) Old Jan 30th, 11, 01:06 PM
try this LINK
68 Camaro~LSx ~all motor
post #6 of 8 (permalink) Old Jan 30th, 11, 01:15 PM
Trey Burks
Depends on the shock too, I forgot about my air shocks.
04 F150 4 door 5.4
post #7 of 8 (permalink) Old Jan 30th, 11, 05:38 PM
.gearhead.'s Avatar
I know Bogarts or Holeshots can be ordered with unusual backspacing, like 4-7/8" or similar. One thing I've heard is that a 9" wheel with a 4-7/8" backspacing fits well with slicks, so that might be worth looking at. I've just never been a fan of spacers if it's going to be raced at all. Maybe just paranoid.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #8 of 8 (permalink) Old Jan 30th, 11, 07:00 PM Thread Starter
mike chiarito
Dude sweet link I have no idea why when I searced I couldnt find that post thanks allo!
shadys69 is offline
