Another will it fit Tire Size Question - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 30th, 11, 05:56 PM Thread Starter
Benito
Need help and I did use search(I say that everytime I post)
Here is my setup and Im looking for Max Tire Size and Width. Also Keep in mind Im going with a hotchkis suspension package which will lower the rear 1.5 inch and the front 2inch I believe. My current tires are ungodly skinny.
Rears
15x8 4.5inch backspace/ Current tires 205/60/15
14x7 (not sure of backspace yet) /Current tires 205/60/14
Also if the hotchkis setup lowers the front an extra half inch will I have to get a little taller tire in front. Thanks in advance. Ill pull the front tire off later. Also if there is a website that will figure out back space along with lowering a vehicle extra Id like to know.
malinois1983 is offline
post #2 of 5 (permalink) Old Jan 31st, 11, 04:48 PM
Jon
Re: Another will it fit Tire Size Question
255/60/15 in rear will fit 195/60 in front on a 15" rim
JR67RS is offline
post #3 of 5 (permalink) Old Jan 31st, 11, 05:41 PM
.gearhead.'s Avatar
If it's a '67 or '68, you should be able to fit a MT 275/60/15 Drag Radial, or a MT 28x10.5 ET Drag, or a 28x12.5 ET Street on a 15x8" wheel with 4.5" backspacing on the rear. All fit with no rubbing on my '68 with stock suspension.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #4 of 5 (permalink) Old Jan 31st, 11, 05:47 PM Thread Starter
Benito
Ok thanks appreciate the help
Originally Posted by .gearhead. View Post
If it's a '67 or '68, you can fit a MT 275/60/15 Drag Radial, or a MT 28x10.5 ET Drag, or a 28x12.5 ET Street on a 15x8" wheel with 4.5" backspacing on the rear. All fit with no rubbing on my '68 with stock suspension.
So I wonder if I lowered it 1.5 in the rear would that still fit?
post #5 of 5 (permalink) Old Jan 31st, 11, 06:08 PM
.gearhead.'s Avatar
I think that would be okay with the 275 DR, but it would be close. I realize the specs show 28" for all of them, but the lip on the ET Drag and ET Street was closer to the fender trim than the radials. I think it's squared off more.
Now: Boost...
