TT2 3.5BS 215/60R15 Ft & 275/60 Fit on 69? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 13th, 11, 10:17 AM Thread Starter
Nick
I have an opportunity to buy a set Torque Thrust II 15x8 &15x6 with BS 3.5. BFG 215/60R15 & 275/60R15. Will it fit my 69 Camaro? I am not sure if the back spacing is enough.
Thank,
Nick
69 Camaro, 327, Auto, Console, Deluxe Interior, AC, Med Green, Exterior Style Trim, 3.08 rear end. Owned since 1983-1st car.
digi-69 is offline
post #2 of 3 (permalink) Old Feb 13th, 11, 02:53 PM
joseph l clance
joe clance's Avatar
Re: TT2 3.5BS 215/60R15 Ft & 275/60 Fit on 69?
i'm not sure if they have enough b/s, but the narrow rim (6") and 215 front tire may let you get away with it. the 275 rear might be tight to the outside also. see if the guy will let you put them on a test drive them.
i have a set (4) of 17 x 8 with 4.75" bs TTII's laying around the garage with (2) bfg KDW 245 45r and (2) 245 40r's that i had on my 69 with no problems
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
post #3 of 3 (permalink) Old Feb 13th, 11, 02:59 PM
Andrew
Andrew69's Avatar
The 8" wide TTII needs 4.75" B/S to center the tire in the fenderwell. I have 4.75" B/S with 255 tires and have just enough clearance on the quarterpanel side.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
