Need advice on what size 18 wheel will fit my camaro? - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 18th, 11, 10:44 AM Thread Starter
Stan
hey guys,i want to put 18 wheels on my 1968 camaro,want to know what size u guys suggest will fit a stock car.also what tire sizes for rims.thanks guys!!
bmf5150 is offline
post #2 of 6 (permalink) Old Feb 18th, 11, 11:12 AM
Matt
Re: Need advice on what size 18 wheel will fit my camaro?
Do some searching as there is lot's of good info here regarding this subject.
Max rear size: 9x18 rims with 275/40/18 tires.
Max front size: 8x18 rims with 245/40/18 tires.
That rear size is very common around here and most including me run them with 5.25 backspace without any issues.
Fronts can be troublesome when pushing the max size limit. Some people get away with it some don't. The wheel and backspace (4.75-5.0) combo must be just right or you'll have rubbing issues. Also, dependents on what other mods/options you have (disc brakes, lowering springs, tubular a-arms, etc) and even stock cars are a little different from one car to another. 7x18 rims with 225/45/18 with 4.25 backspace will fit not problem as that's what I got. 8x18 rims with a 235 tire should be less troublesome as well...
Matt
zlek131 is offline
post #3 of 6 (permalink) Old Feb 18th, 11, 01:55 PM Thread Starter
Stan
Thank you for ur help!I have stock suspension but do want to upgrade to the c5 brakes!don't think that will be issue with these rims?
bmf5150 is offline
post #4 of 6 (permalink) Old Feb 19th, 11, 08:01 AM Thread Starter
Stan
So what do u guys think?c5 brakes with these rim and tires sizes
bmf5150 is offline
post #5 of 6 (permalink) Old Feb 19th, 11, 06:52 PM
Matt
I don't know a lot about the c5 setup but with a 18" rims most if not all kits should fit just fine.
Matt
zlek131 is offline
post #6 of 6 (permalink) Old Feb 19th, 11, 08:22 PM
18" is easily big enough diameter-wise unless it's a super funky design. You still need to check however - it's often the spoke design that doesn't allow for clearance. In other words, due to the C5 rotor's relatively shallow hat dimension, the caliper can hit the spokes. Go to www.kore3.com, download and print the fitment template.
BPOS is offline
