what is the correct backspacing for a 1968 with 15''x7" rally wheels ? - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 22nd, 11, 08:39 PM Thread Starter
rohan
hi guys,
hope you can help me.
i have a 1968 camaro with 15" x 7" rally wheels and firestone firehawke tyres p215/65r15. i have been told these wheels and tyres should be fine, but when i hit a dip in the road my front tyres rub / scrape against the wheel arch trim.
i am wondering if the back spacing is incorrect and would like to know what it should be ? also the trim rings sit about 20mm out from the the wheel centre. should the trim ring be hard up against the centre of the wheel ? any help would be appreciated.
thanks heaps,
cheers guys,
rohan
malley67 is offline
post #2 of 10 (permalink) Old Feb 22nd, 11, 08:52 PM
Bobby
Re: what is the correct backspacing for a 1968 with 15''x7" rally whee
What is the backspace on your rims?
I have 15x7 with 215/65 tires w/ 4.25" backspace on the front of a 67, haven't driven it too much with this set up because of the weather but so far no rubbing.
Can't comment on the trim rings, sorry.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #3 of 10 (permalink) Old Feb 22nd, 11, 09:07 PM Thread Starter
rohan
thanks for that. i dont know what backspacing i have at the moment. i have just started looking into it. just thought i would throw it out there and see what comes back. i got 4.25" on crg also, so thats good confirmation.
cheers,
rohan
malley67 is offline
post #4 of 10 (permalink) Old Feb 22nd, 11, 09:38 PM
Steiner
4.25" will clear even with a 235 tire. If they are a GM rally rim, you can look for a code stamped by the valve stem and decipher it here:
http://forums.corvetteforum.com/1575168356-post7.html
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 10 (permalink) Old Feb 23rd, 11, 01:42 AM
Garth
Rohan, There's a gap, not sure how much exactly, between the trim ring and wheel center on a 4.25 bs, 15 x 7. I seen your car pictured at CRG.....http://camaros.org/images/pages/cars...alley-Full.jpg
They look like 4.25 bs rims. Sets pretty low... I kinda think it's suspension related ?
Front disc brakes ?...aftermarket or GM ??
Garfields Maro is online now
post #6 of 10 (permalink) Old Feb 23rd, 11, 03:51 AM
Rick
Also, what are the alignment specs? If you don't have any negative camber you might get a rub when bottoming out.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #7 of 10 (permalink) Old Feb 23rd, 11, 03:44 PM Thread Starter
rohan
hi rick,
i dont know what the alignment specs are ?
how do i find out this ?
thanks heaps,
rohan
malley67 is offline
post #8 of 10 (permalink) Old Feb 23rd, 11, 03:51 PM Thread Starter
rohan
hi garth,
yes, that is my car on crg at the moment.
if it is suspension why would the tyres hit the wheel arch mouldings ? shouldnt the tyres go up and down without hitting the wheel arch trim. thats why i am leaning towards backspacing and tyres and this stage. i have front disc brakes stock and new calipers from classic industries. also what does bs mean next to 4.25" ? thanks heaps for your help. i really appreciate it.
cheers,
rohan
malley67 is offline
post #9 of 10 (permalink) Old Feb 23rd, 11, 04:22 PM
Bobby
Hi Rohan,
bs is acronym for backspace.
Regarding alignment specs, a little extra negative camber will tilt the top of the wheel in a bit as the suspension travels upward possibly enough to avoid rubbing, if I understand it correctly
67 Camaro 350
M20 4spd console,
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #10 of 10 (permalink) Old Feb 24th, 11, 01:26 AM
Garth
Thanks Bobby, for clearing that up...no bs intended.
Rohan, you're on the right track...for some reason, the tires are too far outboard. I'm just going by the fact that 215/65 15 on 15x7, 4.25 b/s is a popular choice and I've never heard of any clearance issues. You need to verify the b/s, either by measuring or looking for a code by the valve stem, as Steiner mentioned. Factory disc brakes do move the wheel out about 1/4" compared to drum. I dunno about aftermarket set-ups...could be more or less. I wonder about the actual dimensions of the Firestone compared to T/A's ? Could be wider or taller ? If not the tire/wheel set-up...not the disc brakes, it would have to be something associated with the suspension, I'd think. Could be something as simple as a slight camber adjustment ??
Just food for thought......
