back space not sure - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 26th, 11, 09:27 PM Thread Starter
back space not sure
Do I put a straight edge accross the wheel or do I need to cut it to fit inside the outter mounting flang?
40buickcoupe is offline
post #2 of 5 (permalink) Old Feb 26th, 11, 11:10 PM
Garth
Re: back space not sure
No cutting needed, just across outer edge.
From inboard flange to mounting pad. Here's a diagram....https://www.rsracing.com/tech-wheel.html#wheeltrm
Garfields Maro is online now
post #3 of 5 (permalink) Old Feb 27th, 11, 04:44 AM
http://www.vintagewheelworks.com/tech-backspace.php
68 Camaro~LSx ~all motor
post #4 of 5 (permalink) Old Feb 27th, 11, 07:42 AM
DjD
DjD's Avatar
I think this drawing from the same page Garth links to really helps show why there is so much backspacing confusion. Note where the wheel (rim) width measurment is taken from.
Then use this drawing to see where the backspacing (rear spacing) measurment is taken from.
...Dennis
DjD is offline
post #5 of 5 (permalink) Old Feb 27th, 11, 08:20 AM
Lonnie
Lonnie P's Avatar
The confusion seemed to stem from years ago when it was measured from the mounting bead. eg. It used to be a 8" wheel with 4" BS was zero offset.
With the advent of aluminum wheels & positive offsets there was a lot more problems with wheel interference to adjacent suspension components. Now wheels are based on offset with respect to the tire centerline vs. mounting face. The backspace is the rear dimension with a straight edge acoss the rear of the wheel. This is typically approx 1/2" more than the bead dimension. The same 8" wheel w/ zero offset would have roughly a 4.5" backspace.
Lonnie P is offline
