Steel wheel (vintiques) back space question-67 - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 28th, 11, 07:30 PM Thread Starter
Terry
Lacking a little confidence here... I wanting to order stock looking steel wheels (15" x 8") for the rear and run hub caps all the way around. But, rather than go thru this process 2 or 3 times, i would like some guideance from someone who knows. My 67 has a stock monoleaf 10 bolt rear.
Question(s):
>Will a 275/60/15 tuck up in my wheel well without modification if, I have the correct back spacing.
>If so...What back space do i need to order?
>If not...How big of a tire can I get that will tuck up?
Also, looking for opinions...Should I run 14" x 6" with 70 series tires up front or 15" x 6" with 60 series?
tminor1966 is offline
post #2 of 2 (permalink) Old Feb 28th, 11, 07:52 PM
Randy
Re: Steel wheel (vintiques) back space question-67
i have 15x8 billet specialties street lites with 4.5 bs with 275/60/15 M/T drag radials, they fit perfect, fronts are 15x4 with 2.25 bs with 165/80/15. have to get a pic of them on the car, still have the old pro stars on my pic on here.
1967 camaro, 327, 9.7 CR, comp cam xs274solid, vortec cylinder heads, edelbrock vortec performer rpm, 750 annular carb, HVH 2" spacer, msd pro billet w/6A box, turbo 350 trans, 3500 stall, 4:10 gears, caltracs suspension, m/t drag radials.
rkmjbad67 is offline
