Wheel/Tire combo coupled with suspension question - Team Camaro Tech
post #1 of 16 (permalink) Old Mar 7th, 11, 12:36 PM Thread Starter
Hi guys,
I have a '69 and have been looking around at different suspension set-ups. I plan to go with the following:
Front - 17x8 w/ 4.5 bs and 225/45/17
Rear - 17x9.5 w/ 5.5 bs and 275/40/17
I have been looking at the new Hotchkis TVS kit which lowers 3 inches all around, but have not found any information on whether or not I will have fitment issues. Could someone help shed light on this for me? Thanks in advance.
Explorer is offline
post #2 of 16 (permalink) Old Mar 7th, 11, 06:48 PM
Sean
Re: Wheel/Tire combo coupled with suspension question
3 inch in the back might be to low for those wheels/tires....but with air shocks you could pull it off...I just did the hotchkis leafs in the rear (1.5")...and used their 2 inch drop coils in the front...Ive got 19's on it and am having rubbing issues....I am going with a 17 inch set up soon and I think it should be the perfect combo.....
The stance is perfect, however it would look even better with a 3 inch drop. I havent had any scraping issues whatsoever, so I might go down a lil lower with the new rims
1969 - 383, 4sp.,
irish420 is offline
post #3 of 16 (permalink) Old Mar 7th, 11, 08:13 PM Thread Starter
Thanks Irish. I don't mind having to angle up steep driveways, etc but I would like it high enough to get it on a trailer from time to time.
From a few posts that I've read, it seems that a number of people who had the Hotchkis suspension set-up that you do wished they would have went a little lower. If I could go with the 3 inch drop with no real issues, I think I would do that, but I may compromise and go with the Detroit speed 2 inch drop.
Explorer is offline
post #4 of 16 (permalink) Old Mar 7th, 11, 09:45 PM
class67's Avatar
You will be happier with a 4.75" bs in front and a 5.75" bs in the rear!
67 Camaro RS
class67 is offline
post #5 of 16 (permalink) Old Mar 7th, 11, 09:51 PM Thread Starter
Steve - Why do you say that? Better fitment?
Explorer is offline
post #6 of 16 (permalink) Old Mar 7th, 11, 09:56 PM
class67's Avatar
Yes, you will have less / no issues with rubbing when the car is lowered. I am running 18x8 in front with 4.75 and a 245/40 with no problem.
67 Camaro RS
class67 is offline
post #7 of 16 (permalink) Old Mar 7th, 11, 10:15 PM Thread Starter
What are you running in the rear and how did you lower all around?
Explorer is offline
post #8 of 16 (permalink) Old Mar 7th, 11, 10:19 PM
class67's Avatar
I am running 18x9's with a 5.5" bs and 275/40's right now but I used to have 9.5's and did run a 5.75 bs on those. I am lowered in front with QA1 coil overs and in the rear I have the Hotchkis drop leafs.
67 Camaro RS
class67 is offline
post #9 of 16 (permalink) Old Mar 7th, 11, 10:22 PM Thread Starter
How do you like the hotchkis? 1.5 or 3inch?
Explorer is offline
post #10 of 16 (permalink) Old Mar 7th, 11, 10:39 PM
class67's Avatar
I have 3" and they are really good springs. Coupled with the QA1 shocks that I have in the rear too, it makes for a firm ride but not to bad.
67 Camaro RS
class67 is offline
post #11 of 16 (permalink) Old Mar 8th, 11, 08:05 AM
dondb's Avatar
Buy the Hotchkis TVS 2" drop in the front with the 1.5" rear drop leafs... Then buy the Hotchkis L&U a arms will get you a 2.5" front drop then use a 1/2" lowering block on the rear for a 2" drop. That will put you right between the 2" and 3" drop with upgrading your steering at the same time That's what i plan on doing (already bought the stuff) when i get my car out of storage this April. I run a set of 17" VWW's 45's with 8" fronts tire is 255x45, rears are 9.5, tire 275x40, car is all ready lowered 2" in front and 1" rear and plenty of room.
69 X-44 Camaro, slowly upgrading to my liking...Hmmm, i guess i'll never be done
2002 Camaro LE SS...Many upgrades
1969 Step Side LWB C10
dondb is offline
post #12 of 16 (permalink) Old Mar 8th, 11, 09:15 AM Thread Starter
Thanks Don. Do you have pics of your current set-up?
Explorer is offline
post #13 of 16 (permalink) Old Mar 8th, 11, 10:23 AM
dondb's Avatar
Current set up is stock front springs cut 2" by PST with 5 leaf replacement leafs with a 1" lowering block....drives like crap. Those are the new wheels and tires though.
dondb is offline
post #14 of 16 (permalink) Old Mar 8th, 11, 01:05 PM Thread Starter
Don - I like the stance. Why not just go with the DSE 2 inch drop all the way around?
Explorer is offline
post #15 of 16 (permalink) Old Mar 8th, 11, 04:35 PM
dondb's Avatar
I used all Hotchkis parts on my 02 LE and was really happy with the quality plus the tech help when i was installing it.
dondb is offline
