how to determine backspacing? - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 27th, 11, 05:20 PM Thread Starter
Steven
stamatisg1977's Avatar
hello. when im ready to buy new rims and tires, i would like an 18" rim with a deep lip but dont want the tires to stick out of the fenderwell. i have the prodigy 4-link and jason rushforth suggested an 18"x10" wide rim with a 5.75 back spacing but that was when i had the stock leafs. so i would like to dive in and take some of my own measurements.
here are some pics
thank you for any input!!
Steven
ID:	21465   Click image for larger version
ID:	21466   Click image for larger version
ID:	21468   Click image for larger version
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 8 (permalink) Old Mar 28th, 11, 04:14 AM
Tim
Re: how to determine backspacing?
Steven,
Try this link - it's an Aussie site, can't help promoting home-grown
http://www.rsmotorsport.com.au/techn...wheel_info.pdf
I found this a while ago and it has a lot of useful info on it, so hope this is of use to you.
Your car is looking really good with that 4-link!!
Cheers Tim
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #3 of 8 (permalink) Old Mar 28th, 11, 04:40 AM
DjD
DjD's Avatar
Same info has been available from this US site for years... https://www.rsracing.com/tech-wheel.html
...Dennis
DjD is offline
post #4 of 8 (permalink) Old Mar 28th, 11, 06:57 AM
Greg
Since your leaf's are gone and shocks are inboard, now is a good time for mini tubs.......
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #5 of 8 (permalink) Old Mar 28th, 11, 05:10 PM
Tim
Hmm - chicken or egg scenario? Looks like your link is probably the original source, so chalk one up to the US! Anyway, hope it helps Steven determine what wheels to go with. Cheers - Tim
ZLP955 is offline
post #6 of 8 (permalink) Old Mar 28th, 11, 06:47 PM
joseph l clance
joe clance's Avatar
i run rushforth 18X10's with 5.5" backspacing and leaf springs. the spring is not the limimting factor, it the inner wheel well. i have 3/4" to the innerwell at its closest pointat 5.5" backspacing. i would hesitate to go any further inboard without mini tubbing.
you can get more of a deep dish @5.5" of backspacing if you tell Jason to hold the pad width to one inch. The thinner the pad, the more outer rim is exposed. a thick pad forces him to move the center piece out to maintain the backspacing.
joe c
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
post #7 of 8 (permalink) Old Mar 28th, 11, 08:37 PM Thread Starter
Steven
thanks Dennis, I totally missed that sticky. Joe, thats great info. i just dont want the tire to hit the wheel well lip as the 4-link does lower the rear 3". i just want to be sure before i drop mega millions on new rims and tires. and i better start doin the math now even tho im about a year away from getting them
Tremec TKO 600
post #8 of 8 (permalink) Old Mar 28th, 11, 09:04 PM
joseph l clance
joe clance's Avatar
three inches of drop is gonna be tough at 10" width. i had to bend the heck out my outer wheelwell and lip to get 10 X 18 @5.5b/s with 285-35-18 at two inches of drop.
if your in the sheet-metal stage, i'd cut/mini tubb-it! then you could go 11+" wide and put it wherever you want.
