how big ? - Team Camaro Tech
post #1 of 33 (permalink) Old Apr 8th, 11, 10:27 PM Thread Starter
Chris
how big ?
How big of a tire can I fit in my 68 if its mini tubed and the leafs are still in stock location? Im wanting to try and run a 15x10 wheel and as much rubber as possible.Thanks
CMQuickcoupe is offline
post #2 of 33 (permalink) Old Apr 10th, 11, 01:35 PM Thread Starter
Chris
Re: how big ?
Anyone?
post #3 of 33 (permalink) Old Apr 10th, 11, 05:49 PM
Greg
Re: how big ?
What about your shocks? Inboard or original location?
How wide are your tubs?
Is the leaf the hard limit factor?
Big sidewall tires flex a lot, and you cannot get as close to the leaf with a doughnut tire like you can with a low profile tire.
You will probably have to mock it up and take measurements to be safe.
I don't know anyone that has tubbed a car and not followed through with moving springs, since that is the easiest part of the project.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #4 of 33 (permalink) Old Apr 10th, 11, 06:59 PM Thread Starter
Chris
Re: how big ?
shocks will be inboard
tubs are the dynacorn pieces stated as 2" wider than stock but i think more than that
yes leaf is hard limit factor but im pretty sure im gonna go ahead and move them if i can figure out what kind of tank setup i can run,dont realy want to put a cell in the trunk but dont want to spend 1k on a tank either
I will be running 28" tall drag radial tires
post #5 of 33 (permalink) Old Apr 11th, 11, 12:57 PM
Greg
Re: how big ?
I made my own offset shackles, and they are @ 1.25" offset. That is the limit that you can go and still use a stock tank with no mods.
I did not notch my frame rails, and now the rails are my hard limit.
I'm running 18 x 10 wheels, a 315 series tire is about it for my application.
I stayed with 10" rims (11" would easily fit) but the extra cost for the non standard, upsize 1" just did not make sense.
1969 RS/SS Vert
chops is offline
post #6 of 33 (permalink) Old Apr 11th, 11, 01:22 PM
Jon
Re: how big ?
I have the same set up. 10'' rim with shocks inbound. The most I could get on the rear was a 28"od with a 12" section width on a 15". My car is lowered 1.5" in rear. If i go any wider the side wall will rub wheel lip. I also have less than a 1/2 clearance between sidewall and leaf spring. I think on a drag radial the most you will be able to fit is a 275/60 bfg or a mt 295/55. I tried a 325/50 bfg drag radial with a 13' section and the side wall was just to much. Btw my car is a 67. I do like the idea of moving springs in.
JR67RS is offline
post #7 of 33 (permalink) Old Apr 11th, 11, 04:36 PM Thread Starter
Chris
Re: how big ?
Do you have any pics of your offset shackles? That would work great to use a stock tank and I have alittle more room for tires as my car is now mini tubed,Thanks
post #8 of 33 (permalink) Old Apr 11th, 11, 07:04 PM
Greg
Re: how big ?
Here is a shot from metal stock to finish. I think I made the driver side first, and the last metal piece is turned around for the camera.
I wanted to emulate the relative size, thickness of the stock shackles, with additional support added. I have a '69 so use your own measurements to be sure this is what you want to do, but like I stated 1.25" is the extreme limit to offset and keep an unmodified fuel tank. Even then I used special bolts, with the heads to the tank side, to keep the hardware off the tank. I moved the spring perches inboard accordingly, and that was no big deal either.
I've put it through the acid test of speed bumps, street dips/holes and the like and it is solid with zero tank interference, but again you have to make that call. Good luck!
1969 RS/SS Vert
chops is offline
post #9 of 33 (permalink) Old Apr 11th, 11, 08:12 PM Thread Starter
Chris
Re: how big ?
Thanks for the pics Greg.
post #10 of 33 (permalink) Old Apr 12th, 11, 02:34 AM
Re: how big ?
I would put your wheel back on and measure everything...
I would "think" a 2" wider wheel with 1.5" more tire would fit ?
15 x 10 w/ 6.25"-6.5"BS
and a tire in the 300-315 range ?
Need others with the DSE's to respond
68 Camaro~LSx ~all motor
post #11 of 33 (permalink) Old Apr 12th, 11, 01:54 PM
Jon
Re: how big ?
I would like to see some tire and rim picks along with size
JR67RS is offline
post #12 of 33 (permalink) Old Apr 12th, 11, 04:12 PM Thread Starter
Chris
Re: how big ?
X2^^^^^^
post #13 of 33 (permalink) Old Apr 12th, 11, 04:47 PM
Jon
Re: how big ?
This is a 275/60/15 on a 10'' rim. my inners are up against my frame rails and as you can see I don't have much room left on wheel lip or springs with a 1.5'' drop. I did have a mt with a 12" section width that fit but the tire was way to short at 26'' od. I guess I really need to move springs??? Any feed back or pics
JR67RS is offline
post #14 of 33 (permalink) Old Apr 12th, 11, 04:51 PM Thread Starter
Chris
Re: how big ?
Yours is a stock wheel tub still right?
post #15 of 33 (permalink) Old Apr 12th, 11, 05:00 PM
Jon
Re: how big ?
Nope. The inners are against my frame rails.
JR67RS is offline
