Trim rings - Team Camaro Tech
post #1 of 3 (permalink) Old May 7th, 11, 06:39 AM Thread Starter
Trim rings
Has anyone had the problem of the trim rings spinning and rubbing on the valve stems? i am worried about the the rings cutting the valve stem.
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline
post #2 of 3 (permalink) Old May 7th, 11, 08:54 AM
Re: Trim rings
The OEM trim rings had multiple spring attachment clips, and once they were snugged down they won't move. The more recent after market rings have four clips that really bite into the wheel. Mine have never moved. Once they are clipped on they are very tight.
I have yet to hear of anyone having a trim ring snap a valve stem from rotation.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #3 of 3 (permalink) Old May 7th, 11, 09:33 AM Thread Starter
Re: Trim rings
I must have orriginal ones they have the multiple clips, They twist enough when driving awhile to lay the valve stem over. I may add that only the rears do it.
