Will these wheels fit a 69? - Team Camaro Tech
post #1 of 4 (permalink) Old May 11th, 11, 02:25 PM Thread Starter
Fred
77thor's Avatar
I have a chance to buy 2 - 15x8.5 Torq Thrust D's with 3.5" backspacing very cheaply...
I want to put them on the rear of my 69 Coupe w/basically stock suspension.
From what I have read... there is not enough backspacing.
Any thoughts?
77thor is offline
post #2 of 4 (permalink) Old May 11th, 11, 02:42 PM
Re: Will these wheels fit a 69?
i would have to guess on from what i have researched that you would need a 4.5 or 5" backspace with a 8.5" wheel
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline
post #3 of 4 (permalink) Old May 11th, 11, 03:08 PM
DjD
DjD's Avatar
Any thoughts?
If you want the old school look they will work but you will have to jack up the back of the car quite a bit.
Very common is a 9.5" wide wheel with 5.75" bs, with a 275 tire it will fit inside the fender on a '69. An 8.5" with 5.25" bs would be centered the same, as would a 7.5" wide wheel with 4.75 bs and a 7" wide wheel with 4.5" bs.
That 8.5 is a deep dish wheel and will stick outside the fender lip.
...Dennis
DjD is offline
post #4 of 4 (permalink) Old May 12th, 11, 06:07 AM Thread Starter
Fred
77thor's Avatar
Thanks. That's what I thought.
77thor is offline
