Wheel size wheel to fit 245/60R15 - Team Camaro Tech
post #1 of 10 (permalink) Old May 12th, 11, 10:41 AM Thread Starter
Dan
Smile Wheel size wheel to fit 245/60R15
I have a chance to get 4 new tires (P245/60R15) at a good price. I'm planning to get new rims too. What size rally rims (width and bs) would you reccomend? My cars suspension / height looks pretty standard. Thanks!!!
1968 RS/SS
DelGratta is offline
post #2 of 10 (permalink) Old May 12th, 11, 11:38 AM
Bryon
bcm66's Avatar
Re: Wheel size wheel to fit 245/60R15
Section width of that tire should be about 9.64 inches with widewall height around 5.78 inches. Normal size wheel for that is probably 7 or 8 inches.
I don't think I would run anything that wide on the front. I would on the back.
I ran a similar size tire on my 68 (just slightly wider and a 50 series) and the back ones would rub slightly at times. So I went to a narrower tire. The ones you have listed here will probably be OK.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #3 of 10 (permalink) Old May 12th, 11, 11:42 AM Thread Starter
Dan
[QUOTE=bcm66;1574585]
I don't think I would run anything that wide on the front. I would on the back. [QUOTE]
Yeah, lots of room out back, not so much up front.
1968 RS/SS
post #4 of 10 (permalink) Old May 12th, 11, 11:43 AM
DjD
DjD's Avatar
I've run 245/60 15's on 15x7 with 4.5 bs with no problems on the back of a 1st gen. I've seen them on the front on the same wheel but don't have any 1st hand experience. I know 235/60 15 on a 15x7 4.5 bs works well on the front.
...Dennis
DjD is offline
post #5 of 10 (permalink) Old May 12th, 11, 11:53 AM
Matt
245's on the front tend to fit much better on 69's than 67's/68's. Plenty of threads on here with 67-8 front rubbing issues when using 245 tire on a 8" rim (assuming you'll have 8" rims). Just my two cents...
Matt
zlek131 is offline
post #6 of 10 (permalink) Old May 13th, 11, 07:39 AM
Russ
245/60's fit nice on the rear of my 68 with 15x7 and 3.76BS on TT-D's. I run 225's up front as 245's would rub the outer fender lip like crazy. I'd buy the tires and see if you can trade 2 of them for some 225's.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #7 of 10 (permalink) Old May 13th, 11, 03:02 PM
Banned
Bethanne
Nashville Beth's Avatar
On the back run 15 X 8 with 4.5 backspace. You can get rallys at Summit for about $80 ea.
Nashville Beth is offline
post #8 of 10 (permalink) Old May 13th, 11, 08:05 PM
Brent
67Rally's Avatar
I'm running a 245/40/18 up front on my '67 with 5" BS. I get a little rub on the subframe at full lock on my driver side, but my front suspension was a mess and I'm in the middle of changing it out right now. There was no issue at all with clearance on the fender. I think you could probably get away with 4.75" BS and have decent clearance all around, or go with a 5" backspace and use wheel spacers if needed.
The 245/60/15 will be a little taller than mine, and the sidewalls are going to have a little more flex, so you need to take that into consideration if you go with them. Either way, I think an 15x8 is your best choice with a 245.
67Rally is offline
post #9 of 10 (permalink) Old May 13th, 11, 08:16 PM Thread Starter
Dan
Russ, seeing your pic reminds me of my last 68:
225/6015's do fill out a front wheel well nicely. Guess I'll have to forget about the 245's up front
PS, I am completely jealous you get to go to the Garlic Festival whenever you want!
1968 RS/SS
post #10 of 10 (permalink) Old May 14th, 11, 01:23 PM
Russ
Yeah Dan we live just 1/2 mile from Christmas Hill Park where the Garlic Festival is held but funny enough we usually leave town that weekend and head to the beach.
Russ (RJ)
rj68RS is offline
Tags
p245/60r15
