Drums vs disk rim ? - Team Camaro Tech
post #1 of 12 (permalink) Old May 26th, 11, 03:15 PM Thread Starter
Lex
Lexlas's Avatar
Drums vs disk rim ?
Guys,
When buying rims, say old rally rim style. Does it matter if you have disk brakes in the fronts and drums in the rear. Is there a differnce when buying these old school rally rims to match up with this drum disk combo ?
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #2 of 12 (permalink) Old May 26th, 11, 03:42 PM
Bri
bwcamaro68's Avatar
Re: Drums vs disk rim ?
From what i have found you need 15" rims for the rotor/ drum wheel, 14" will only work for the drum style brakes. due to clearance issues.
I had a set of 15" rally rims 10" wide with 4 1/4 offset rear and 15" x 8" wide for front.
its all in the look you want.
"Three Rules of Work: Out of clutter find simplicity; From discord find harmony; In the middle of difficulty lies opportunity."
Albert Einstein
"Never Forget" FDNY 9/11/01
I have more than 4 Camaro's am I Addicted?
bwcamaro68 is offline
post #3 of 12 (permalink) Old May 26th, 11, 04:04 PM
If that is true, How come only Z's had 15" wheels, SS had disc brakes, so did 6 cylinder cars,????
john68 is offline
post #4 of 12 (permalink) Old May 26th, 11, 04:23 PM
DjD
DjD's Avatar
There are 14" factory wheels that will fit over factory front disc's.
...Dennis
DjD is offline
post #5 of 12 (permalink) Old May 27th, 11, 06:19 AM
Jeff
yellow69RS's Avatar
Look at all the cars with dog dish hub caps and 14" wheels like the copo's. I spent a few days sorting wheels before I found four that cleared my discs. but It can be done. If they fit over the discs they'll clear the drums just fine.
Jeff
yellow69RS is offline
post #6 of 12 (permalink) Old May 27th, 11, 09:19 AM
Sauron67MM is offline
post #7 of 12 (permalink) Old May 27th, 11, 09:24 AM
Vintage 68's Avatar
Wink Re: Drums vs disk rim ?
It's more dependent on Rim Profile than rim size or wheel application identifier code
A 14" "JJ" profile rim will clear caliper - a "J" or "JK" profile rim will not ...
1968 Convertible
Some trucks
Vintage 68 is offline
post #8 of 12 (permalink) Old May 27th, 11, 11:13 AM Thread Starter
Lex
Lexlas's Avatar
Now that is great news, because i have JJ code Rally rims. Now i just need the front ones to match, but they are 15x8 in size.
Lexlas is offline
post #9 of 12 (permalink) Old May 27th, 11, 12:10 PM
The profile is obvious as to which ones fit a disc or not, no? Once you know what a disc wheel looks like your not apt to grab a drum rim by mistake. The ones I have it's clear. Don't the application codes have some relevance?
post #10 of 12 (permalink) Old May 27th, 11, 01:32 PM
Vintage 68's Avatar
Thumbs up Re: Drums vs disk rim ?
Originally Posted by Sauron67MM View Post
... Once you know what a disc wheel looks like your not apt to grab a drum rim by mistake.
... Don't the application codes have some relevance?
I could place two(2) K.H. Rally rims next each other that "look" identical - but, one will clear a caliper and the other wouldn't
It's gets even tuffer for standard 'steel' rims
So you need to know the rim code to be sure.
The application code will give you the original size, offset, width and style as well as intended model use - but may not tell you if they could clear a caliper in some cases. Knowing the rim profile for that rim will allow you to judge that.
Rim profiles were also changed over the years for some common steel wheels to clear calipers as disc systems became more common.
1968 Convertible
Some trucks
post #11 of 12 (permalink) Old May 27th, 11, 04:54 PM
Noted, thanks John.
post #12 of 12 (permalink) Old May 27th, 11, 04:54 PM
Jimmie-Retired
I've accumulated 6 of the 14x7 JJ wheels and yes, they fit over disc brakes. Without looking (it's been awhile), I believe that they are all IC and they are the only wheel that is identical in every way to the much sought after and expensive XT wheel that I've found. They'll probably end up on epay eventually. The garage is getting crowded and the wife has mentioned a couple of times that it would be nice if she could get her car in.
Jim's '69
68 SS 396 4 speed A/C Bought New Sold 1976
68 350/350 A/C Bought 1978 $700 Wrecked
69 350 4 Speed Bought 1988
Fried Okra is offline
