Wheel and Tire storage - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 2nd, 11, 10:07 AM Thread Starter
What is the best way to store a spare set of Rim's and Tire's? Thanks ahead of time
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline
post #2 of 6 (permalink) Old Jun 2nd, 11, 06:38 PM
Re: Wheel and Tire storage
Inflate each tire, bag each tire in a dark garbage bag, secure the end of the bag, store/stack the tires in a controlled enviroment room away from sunlight.
You could visit MailPak, UPS Store, or FedEx, and get a desicant bag for each bag to keep them dry.
post #3 of 6 (permalink) Old Jun 3rd, 11, 04:30 AM
J
I have a follow up question, is it better to stack the tires on top of each other on the floor or should they be side by side on a shelf?
magisnyc is offline
post #4 of 6 (permalink) Old Jun 3rd, 11, 09:17 AM
If just the tire/wheel, you can stand them upright and not worry about flat spotting.
I generally stack them on their sides.
post #5 of 6 (permalink) Old Jun 3rd, 11, 05:46 PM
store them bolted to the car. it's easier.
you don't plan sincerity.
novaderrik is offline
post #6 of 6 (permalink) Old Jun 8th, 11, 12:19 PM
Pete
Black bag is a great idea, ozone in the air will also attack the rubber so its best to make sure that the bag is sealed from outside air as well.
I would NOT leave them on the car, they will flat spot. If you are forced to leave them on the car for longer than a few months at a time I'd crank the PSI up to the maximum written on the sidewall, just make sure you lower it back down before you drive it.
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
