67 vert w hotchkiss system, rims/tires? - Team Camaro Tech
post #1 of 9 (permalink) Old Jun 11th, 11, 06:32 AM Thread Starter
frank
hi TC members. I just finished putting on the hotchkiss system. Wow, what a difference, its going to take getting used to thats for sure. I now need to buy some new rims and tires. Presently, i have 14" ralleys, with 60r234 on the rear and 60r225 on the front. I am thinking of 15x7, 60r245 on the rear and 14x6, 65 or 70r215 on the front. Can anyone offer advice on this or what you have that you're happy with?
viper is offline
post #2 of 9 (permalink) Old Jun 11th, 11, 02:08 PM
Banned
Bethanne
Nashville Beth's Avatar
Re: 67 vert w hotchkiss system, rims/tires?
If you are going to use rallys, the most popular combo is:
Rear: 15x8 with 4.5 to 4.75 backspace, 245 or 255/60/15
Front: 15x7 with 4"? (not sure) backspace and 225/60/15
Nashville Beth is offline
post #3 of 9 (permalink) Old Jun 11th, 11, 03:24 PM
Since you're not going with big wheels nor trying to stuff the biggest possible tire, I suggest using the same setup front and rear so you can rotate them. On my 69, 235/60's fit easily front and rear.
BPOS is offline
post #4 of 9 (permalink) Old Jun 13th, 11, 06:05 AM
1st 67 SS/RS's Avatar
I have 15x7 rallys with 245/60 all the way around. The back is fine but the front is tight, needs to be 235 or 225 with the TVS kit
67 Vert RS/SS 350 4 SP
1st 67 SS/RS is offline
post #5 of 9 (permalink) Old Jun 13th, 11, 06:25 AM
Vince
vincevs's Avatar
I am very happy with this setup... I also have a 67 vert but I have standard drum brakes all around.
- Wheels: 15X7 with 4" bs up front, 15X8 with 4.5" bs in the back
- Tires: 215/65/R15 up front, 245/60/R15 in the back
Vince
69 Base Coupe "The Wrecker" Project -
67 rs/SS L48 4spd Convertible -
- SOLD
vincevs is offline
post #6 of 9 (permalink) Old Jun 13th, 11, 07:32 AM
Russ
Hotchkis springs front and rear, 15x7 with 3.76 BS all the way around. 225/60's in front, 245/60's in rear.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #7 of 9 (permalink) Old Jun 14th, 11, 09:26 AM Thread Starter
frank
gents, thanks for the replies. RJ, your vert looks sweet. Are you happy that your lowered it over 2"on the front...if you had to do it over again, would you? Vince, I went to your page and saw your car...our stories are very much the same. Mine was Sierra Fawn, RSSS 350, but changed it to red in 2001. Are you also using the Hotchkiss
viper is offline
post #8 of 9 (permalink) Old Jun 15th, 11, 07:55 AM
Russ
Frank, I'm real happy with the ride height. I drive this car often around town, highway, even commute to work 100+ miles at times and there are only a few places where I scrape bottom. I would do the same setup again as I like how it turned out and gave me the retro 60's look I wanted.
Russ (RJ)
rj68RS is offline
post #9 of 9 (permalink) Old Jun 15th, 11, 09:27 AM Thread Starter
frank
Smile Re: 67 vert w hotchkiss system, rims/tires?
thanks Russ, I'm convinced. Ordering new rubber on 15's ralleye today
viper is offline
