Question for all the big brake 17"+ wheel guys... - Team Camaro Tech
post #1 of 14 (permalink) Old Jul 1st, 11, 01:39 PM Thread Starter
DjD
DjD's Avatar
Most of you have seen my car, 17" wheels, 13" C5 front brakes etc. Well I rounded up a 2002 Camaro spare tire and it won't fit over the caliper on the front, it fits the C4 brakes in the rear fine. Someone posted they are using a '04-'06 GTO spare and it fits over their C5 brakes.
Cool deal, but in researching this I find the lug pattern on the GTO is 5 x 120mm (4.72) not the 5 x 4.75 common Chevy pattern. I know that's only about .7-1mm or 3/100th of an inch difference so that is my question. Will this slight difference matter?
I have another approach which is to get about a 2" wheel adapter that can be bolted to the hub and the spare bolted to the adapter. Either option is about the same cost since the adapters are sold in pairs.
Thanks for your input,
...Dennis
DjD is offline
post #2 of 14 (permalink) Old Jul 3rd, 11, 05:57 PM Thread Starter
DjD
DjD's Avatar
Re: Question for all the big brake 17"+ wheel guys...
ttt
...Dennis
DjD is offline
post #3 of 14 (permalink) Old Jul 7th, 11, 01:17 PM
Jeff
68IslTeal's Avatar
since its a spare i would say your ok. I have seen people run bmw wheels on camaros etc... and that is basically the same scenario, but they run them full time.
68IslTeal is offline
post #4 of 14 (permalink) Old Jul 7th, 11, 05:35 PM
Tim
It may only be marginally off the right PCD, but it will tend to bend your wheel studs slightly, and therefore shouldn't be recommended. As Jeff said, being a spare wheel, you're probably OK to use it in an emergency, but not as a regular thing. Here in Aus, one of the most popular GM Holden cars, the Commodore, uses a 120.65mm PCD, and you can get these later style wheels to fit older Holden hubs that share the same PCD as Chevy (5x4.75"), but it is generally considered a bad thing to do because the wheel studs are placed in additional bending (that they are not designed for), when you try to torque the lug nuts up to specs. When you talk to guys who have done this, you hear some pretty bad stories of wheel not torquing up properly and wheel stud failure.....
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #5 of 14 (permalink) Old Jul 11th, 11, 08:38 AM Thread Starter
DjD
DjD's Avatar
Thanks for the replies, I've never had a flat but the miles are adding up over the years now. I'm kicking around the wheel adapter idea more and more. I'll have to start looking for someone that has an adapter laying around to give one a try. I'd hate to buy only to find out it pushes the spare into the outer fender.
...Dennis
DjD is offline
post #6 of 14 (permalink) Old Jul 11th, 11, 04:55 PM
Kevin
SixtyAte's Avatar
Dennis...
Will this fit ?
http://shopping.yahoo.com/846683393-...eel-wheel-rim/
Here's the short list of stock wheels that will fit the sol:
(Make/Model; Year(s); bolt circle; hub dia.; offset)
Chevy HHR 06 - 5x110mm; 65.1mm; +42mm
Cadillac Catera 96-01 - 5x110mm; 65.1mm; +51mm
Chevy Cobalt SS 05-06 - 5x110mm; 65.1mm; +49mm
Chevy Malibu/Malibu MAXX 04-06 - 5x110mm; 65.1mm; +42mm
Pontiac G6 05-06 - 5x110mm; 65.1mm; +42mm
Pontiac Pursuit GT 06 - 5x110mm; 65.1mm; +49mm
Pontiac Solstice 06 - 5x110mm; 65.1mm; +55mm
Saab 9-3 99-06 - 5x110mm; 65.1mm; +41mm
Saab 9-5 99-06 - 5x110mm; 65.1mm; +49mm
Saturn L-Series 01-05 - 5x110mm; 65.1mm; +45
Saturn Sky 06 - 5x110mm; 65.1mm; +55mm
Saturn Ion Redline 04-06 - 5x110mm; 70.3mm*; +49mm
Kev
SixtyAte is offline
post #7 of 14 (permalink) Old Jul 12th, 11, 05:25 AM
Chris
130fe's Avatar
Post Re: Question for all the big brake 17"+ wheel guys...
Dennis, I read somewhere (can't seem to find it) that using a 1/4" spacer will make the LS spare work with the C5 brake. Have you considered that option? It would only be a temporary measure so I don't think the spacer would be an issue (unless your wheel studs aren't long enough to allow the spacer).
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #8 of 14 (permalink) Old Jul 12th, 11, 05:32 AM
Chris
130fe's Avatar
Chris
130fe is offline
post #9 of 14 (permalink) Old Jul 13th, 11, 02:54 AM
Kevin
SixtyAte's Avatar
Cool Re: Question for all the big brake 17"+ wheel guys...
Hey Dennis...
Did you find a solution?
Kev
SixtyAte is offline
post #10 of 14 (permalink) Old Jul 13th, 11, 08:49 AM Thread Starter
DjD
DjD's Avatar
Sorry Kev I got side tracked, I am juggling 3 employment opportunity's, have been interviewing and don't want to burn any bridges in case the one I really want doesn't pan out.
Anyway the ones you suggested are all 5x110mm bolt pattern which won't fit. The 5x4.75" that our Camaros and most old Chevys are is very close to 5x121mm.
Chris I was hoping your suggestion would pan out as I have some 1/4" spacers but the 2002 Camaro spare I have hits the caliper before the lugs hit the holes in the wheel.
I have a call in to a friend that may have an adapter I can try and if he does I'll post back the results.
...Dennis
DjD is offline
post #11 of 14 (permalink) Old Jul 13th, 11, 11:03 AM
Brent
67Rally's Avatar
How about a C5 wheel?
67Rally is offline
post #12 of 14 (permalink) Old Jul 13th, 11, 12:15 PM Thread Starter
DjD
DjD's Avatar
The backspacing would be 7-8" which wouldn't work as well the convertible top folds down into the trunk so space is already limited.
...Dennis
DjD is offline
post #13 of 14 (permalink) Old Jul 14th, 11, 10:47 AM
Rich
Dennis I would think the GTO wheel would be fine that little difference
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #14 of 14 (permalink) Old Jul 14th, 11, 06:15 PM
Brent
67Rally's Avatar
Agreed, especially as a spare. As stated above, I've seen several people post that they are running BMW wheels (same lug pattern as GTO) on all 4 year round without any problems. If you are just using it to get back home I can't imagine it would cause any issues.
67Rally is offline
