BFG TA Radial Tire choice for 69 14x7 - Team Camaro Tech
post #1 of 11 (permalink) Old Jul 15th, 11, 05:12 PM Thread Starter
69-Pace's Avatar
Ok finally time for new tires.
I like the look of BF Goodrich TA Radials. From what I can tell the ride is comfortable and the performance is a thousand times better then the originals.
Been poking around and from what I hear and see the BFG TA Radial sized 225/70/14 will fit without any rubbing issues on my factory 14x7 Rally wheels on my 69 Z11. I also don't want to have to change speedo gears etc.
Am I correct?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #2 of 11 (permalink) Old Jul 15th, 11, 05:32 PM
Re: BFG TA Radial Tire choice for 69 14x7
I used 235/60-14 BFG RTA's on my 69 with 14 x 7 rallys with zero rubs. Nice looking tars.
BPOS is offline
post #3 of 11 (permalink) Old Jul 15th, 11, 06:23 PM
same here - BFG 235/60-14 Radial TA' s
69 Pace Car and 69 Hard top
srode is offline
post #4 of 11 (permalink) Old Jul 15th, 11, 07:40 PM
Dale
Did you use the same size for front and rear???... this size seems a bit wide for the front.. ?
When You Turn Your Car On,, Does It Return The Favor,??.. NO!.. Butt,, I hope to Change That Soon..
gonewacky is offline
post #5 of 11 (permalink) Old Jul 15th, 11, 07:55 PM Thread Starter
69-Pace's Avatar
Did you have to change out your speedo gear to keep it accurate?
69-Pace is offline
post #6 of 11 (permalink) Old Jul 15th, 11, 10:46 PM
Steps
I have run (see links in my sig) 14x60x235 for near on 30yrs, on all 4 cnrs
Used to have BF yrs ago, but for road use found them a bit soft and not as long lasting...and bloody expensive in NZ...which is more expensive and short lived if showing off lo
Now I just what ever has white lettring on, and they tend to harder, longe lasting and let loose a LITTLE easier when showing off.
Personally if I did have the extra bucks in the back pocket I would go for the 15 rims..fills the wheel well nicer, and the same width are a damn sight cheaper, easier to get.
Only if the diam is different to what u have now....if it is its no big deal...
Take the gear out in the tail shaft, couple minutes, count the teeth.
Mesure the % difference in Circumferance between the old tyres and new, and change the teeth number the same %......assuming the odometer was reading correct before.
OR put the tyres on...simple do a distance check against google earth or known distance....10 miles + work out the % error, count the teeth and change the gear the same %.
Steptoe is offline
post #7 of 11 (permalink) Old Jul 16th, 11, 02:16 AM
Yep, same size front and back - They brushed the vacum can cover for the headlight door a bit on compression when turned to the locks before the restoration but that was with the original coil springs. After a complete rebuild they do not rub anywhere anytime.
What's a speedo? Seriously, I didn't touch it and it seems to be pretty accurate judged by keeping pace with traffic on the highway at 65 to 70 mph - it might be off a couple mph plus or minus but not by much. I haven't driven it enough to find one of those speed reporting trailers the city and state leave on the roadside to see what it is really doing vs the reported on the speedo but I don't think it's too far off. I guess if compare the original tire circumference to this one it will tell you how close it should be, just never bothered to figure it out.
srode is offline
post #8 of 11 (permalink) Old Jul 16th, 11, 08:03 AM Thread Starter
69-Pace's Avatar
Thanks Al, Steve, nice ride Steps
The original F70x14's rated at 769 revs per mile,
the BFG 235/60-14 Radial TA' s rate at 820 revs per mile a difference of 51 revs per mile.
So I guess smaller height of 60 vs. 70, wider stance of 235 vs. 225 would still keep the true MPH lower than factory ties and current speedo calibration.
If I have calculated this right the ride height is about and 1 and 1/2 inches lower then factory stock right?
Steve - you rebuilt coil springs with OEM style or aftermarket parts? I'm concerned that I will also scrub off the RS actuators with the front tires being that wide.
69-Pace is offline
post #9 of 11 (permalink) Old Jul 16th, 11, 12:03 PM
I have on my 69 RS Bf Goodrich T/As with size P225/60R/15 front and P235/60/15 on the back . has 15/7 GM slotted rally rims. front end has aboutone and half in drop . goods cool and never any turning or front problems.
rockin rollin is offline
post #10 of 11 (permalink) Old Jul 16th, 11, 02:45 PM
Brian, they are OEM style springs, front and rear. I think you should be fine with good springs - saggy ones may rub some depending on how old they are.
Based on the tire revs - you should be going about 4 mph slower than the speedo says at 60mph.
The original tires were 26.2 inches and the 235 60 14s are 25.1 inches tall so it should only be a 1/2 inch difference in ride height.
srode is offline
post #11 of 11 (permalink) Old Jul 16th, 11, 09:30 PM
Steps
nice ride Steps
Thanks..daily driver for 30yrs now
I should have added this before...I have had 14x60x235s all round for yrs nps, tow, farmland, rough gravel roads, tow car for the vintage cars etc...
I did try 14x60x245s yrs ago, on the rear, but a couple ppl in the rear seat, rubbed going over a bump in the road...just touched the shock occassionally and just touched the lip inside the fender
Steptoe is offline
