Need some advice - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 17th, 11, 08:13 PM Thread Starter
Gene
Need some advice
I just installed stock springs #6312, 2" drop spindles, 225-60-15 BFG radial TA tires. I have a slight tire rub when I am the only passenger on hard bumps or sharp turns. Tonight I took my wife and her friend for a drive and the right front was rubbing on most every dip. I have not been able to determine where it is hitting, I think it is probably the outer lip of the fender. The wheels are 15 x 8 with 4.5" backspacing. My question is, do members think going to a 205-60-15 would solve the problem, looks like that is about 1.4"less in height which would give me about 5/8" more clearance and I would gain some clearance by the tire not being quite as wide. I would like to stay with the 15x8's even though they may be a little wide. Could I put a 195 on a 8 inch rim? Just wondering if any one has already dealt with this combination. Any information or recommendations will be appreciated.
Thanks,
gene68ss
gene68ss is offline
post #2 of 3 (permalink) Old Jul 17th, 11, 09:04 PM
Steiner
Re: Need some advice
It should be fairly obvious on both the tire and fender. I know they have been working on the drop spindles to fix the issue where the tie rod hits the back of the rim with certain setups. Have you checked the back side to see if that's where it's hitting?
If you have standard hex bolts in the fenders those have been known to get caught with certain setups as well. Going to button head allens usually corrects that.
Another thing is if you are running stock alignment is to try to get the camber more negative up to -0.5 which helps the top of the tire lean in more. The stock suspension geometry has the tire moving almost straight up and down which takes more work to fix though.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 3 (permalink) Old Jul 18th, 11, 07:57 AM Thread Starter
Gene
No problem with the tie rods, they are one inch off the wheel/tire. I think the hex bolt may be an issue on turns. It was bearable until I added two passengers and that made the right front rub on any little dip. It sounded like the inner fender but I have not found a mark on the tires or the inner fender. I only have driven a few miles but I know I have to change something to correct this. I had not thought about camber, I just had it aligned and the right front has no shims and the camber is -.07 the left is -0.2. The alignment guy said I would have to have the frame tweaked to be able to get -0.2 on the right front. All other measurements are balanced on the car. I like the look of the 225 but I am hoping a 205 will work; I just don't want to keep buying tires. The radial T/A's have a good look. Thank you for the response, I am going to get out in the garage and see what I can come up with.
gene68ss
http://s1092.photobucket.com/albums/i405/gene68ss/
1968 SS 383 Stroker
gene68ss is offline
