Where can i get center rings? - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 18th, 11, 08:47 AM Thread Starter
Hi, i have the problem, that the caliber of my hub is not the same like the caliber of my wheel.
As you can see on the photo, there is nearly 1cm space between Wheel and hub.
Is it possible to buy a center ring like you can do for modern cars? I could not find any information.
Here is a link to a center ring iīm searching for. Unfortunately it has the wrong measurements:
http://cgi.ebay.de/NEU-METALL-ZENTRI...item3ca29d73f1
My measures are:
hub: 70,80 mm
wheel: 80,5 mm
I dont know the measure in inch, sorry...
mikessaxo is offline
post #2 of 3 (permalink) Old Jul 18th, 11, 10:14 AM
Andrew
Andrew69's Avatar
Re: Where can i get center rings?
I believe the Camaros are designed to be lug-centric meaning the lugnuts center the wheel in place on the hub. The alternate is hub-centric with the center diameter being a size-to-size fit between the wheel and hub. With that said you do not need a spacer, just the correct lug nuts.
Someone else may jump in with a correction but I believe I am right.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #3 of 3 (permalink) Old Jul 18th, 11, 11:01 AM Thread Starter
So if i understand it right, you mean, that there is no need to use a center ring? Everyone here in Germany say, i need to center the Wheel with a center ring. It looks like the lugnuts are designed to center the wheel. If itīs so, i can leave it like this?
Sorry for the questions, but my technical english isnīt so good ;-)....
