rear wheel stud question - Team Camaro Tech
post #1 of 14 (permalink) Old Aug 1st, 11, 07:08 PM Thread Starter
david
I just bought a set of ar hopster wheels for my 68,went to install and I am only getting about 5.5 turns on my lugs.Im guessing that im getting only 3/8 of a inch of thread.From what i have read you need at least a 1/2 inch.They are 7/16 studs probly original to the car.Dont know if 5.5 turns is safe or should I get new studs.Thank you for any answers.
white68 is offline
post #2 of 14 (permalink) Old Aug 1st, 11, 07:15 PM
DjD
DjD's Avatar
Re: rear wheel stud question
Get the tire shop you got your wheels from to give you an un-capped lug so you can see how far the lugs thread on.
...Dennis
DjD is offline
post #3 of 14 (permalink) Old Aug 1st, 11, 07:22 PM Thread Starter
david
I have one off of my rally wheels I will try it out.
white68 is offline
post #4 of 14 (permalink) Old Aug 1st, 11, 07:26 PM
Steiner
Yep, you're not even close. 7/16-20 studs means 20 turns per inch. You need at least as much engagement as the diameter of the stud.
7/16 = 0.4375" = 8-3/4 turns
5.5 turns = 0.275"
It's always something, ain't it?
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 14 (permalink) Old Aug 1st, 11, 07:37 PM Thread Starter
david
So in that case how much longer should my stud be.Thanks
white68 is offline
post #6 of 14 (permalink) Old Aug 1st, 11, 07:45 PM Thread Starter
david
So in that case how much longer should the studs be.I am thinking about a 1/4inch,but I am not the best at math.thanks
white68 is offline
post #7 of 14 (permalink) Old Aug 1st, 11, 07:46 PM
Steiner
Yes, a quarter inch longer at the minimum with 7/16 studs.
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 14 (permalink) Old Aug 1st, 11, 07:53 PM Thread Starter
david
Thank you very much for the info.I will see if nappa has what I need.I havent even tried out my fronts,but i am guessing it will be the same situation nothing is ever easy.
white68 is offline
post #9 of 14 (permalink) Old Aug 1st, 11, 09:25 PM
Jimmie-Retired
I just had to swap out all my wheel studs when I went to a vintage set of AR 200S wheels. Had to buy 2 1/2" studs and shortned to 1 7/8". Did it in my garage. Put a lug nut on stud flush with stud end and drive them out with a BFH. Pulled new ones in with a stack of 7/16 washers and lug nut.
Jim's '69
68 SS 396 4 speed A/C Bought New Sold 1976
68 350/350 A/C Bought 1978 $700 Wrecked
69 350 4 Speed Bought 1988
Fried Okra is offline
post #10 of 14 (permalink) Old Aug 2nd, 11, 02:22 AM
Go to your local parts store and ask to see their Dorman wheel stud box.
I went to 2" due to same problem (forget PN )
68 Camaro~LSx ~all motor
post #11 of 14 (permalink) Old Aug 2nd, 11, 07:57 AM
You might also consider a set of conical lug nuts instead of longer wheel studs. They have a longer shank that grabs about 1/4" more of the threads than a standard lug nut. http://www.jegs.com/i/Billet+Special...99970/10002/-1
Good info on wheel stud part numbers etc. here: https://www.camaros.net/forums/showthread.php?t=108269
BPOS is offline
post #12 of 14 (permalink) Old Aug 2nd, 11, 08:25 AM
Greg
I would try the conicals first like BPOS suggests, may save you some trouble.
If you have stock length studs, you probably need to refresh anyway with 1.5" new studs if you have drums.
I replaced my studs with 2 1/8" (seems to be a standard size, NAPA) , disc brake upgrade, Rushforth Livewires, and when using new conicals I bought with the Rushforths, the conicals botomed out before torquing correctly. I had to go back to standard centric type lugs as I wasn't about to shave the new studs down.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #13 of 14 (permalink) Old Aug 2nd, 11, 08:55 AM
DjD
DjD's Avatar
Most lugs are conical, the ones Al is suggesting have a shank on them and are refered to as ET style. The question is are the AR Hopster wheels drilled to accept the shank on ET style lugs?
Without any math involved, a couple threads showing past the nut using a standard conical non-capped hex nut will pass most dragstrip tech inspections at a street legal fun night.
...Dennis
DjD is offline
post #14 of 14 (permalink) Old Aug 2nd, 11, 01:20 PM
Most like to see a few threads out of the nut (unless closed style) but I think if it was a sanctioned race they'll require at least the length of the diameter of the stud. (1/2" studs = 1/2" of threads showing) and once you hit 9.99 (I think it is, or a certain MPH ?) you'll need longer studs for the front also.
But.... for the street I would think at least a full nut would be ok. (even 3"s of stud showing isn't gonna make it tighter; just if it came loose it would take longer to lose the nut )
