20 inch rear wheels - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 10th, 11, 07:08 PM Thread Starter
Lyndon
20 inch rear wheels
Ok, I have read everything I could find but I still can't get to the bottom of this one. If my 69 is lowered 3 inches in the back with hotchkis leafs, can I put a 20 inch wheel on there and still fit a 275 wide tire? If not, what is the biggest tire, and also what is the widest rim? If I have missed a thread where this is covered, direct me to it if you can. Disc brakes, 8.5 inch ten bolt, aftermarket quarters, lowered three inches from stock.
Buckmclean is offline
post #2 of 7 (permalink) Old Aug 14th, 11, 01:50 PM
Re: 20 inch rear wheels
I have 3" blocks under the rear of my 12 bolt with a stock multi leaf setup and I am running 285/30/20 on the rear of mine. I haven't had any issues with the rear of mine yet.
bkerns925 is offline
post #3 of 7 (permalink) Old Aug 15th, 11, 06:41 PM Thread Starter
Lyndon
Did you have to trim or roll the fender lip? Are the quarters aftermarket or original?
post #4 of 7 (permalink) Old Aug 16th, 11, 05:08 PM
I didn't have to do any trimming or roll the lips. The quarters were replaced at some point before I got the car. There is a little room in the fender well but I wouldn't push the issue by putting a larger wheel and tire underneath it.
post #5 of 7 (permalink) Old Oct 31st, 11, 08:06 PM
I can't say about the 20's but if you have mini-tubs you can go up to 12" wide wheels with those leaves and offset shackles.
Speed has never killed anyone. Suddenly becoming stationary, that's what gets you! Jeremy Clarkson
Headshake is offline
post #6 of 7 (permalink) Old Nov 7th, 11, 03:58 PM
Steven
stamatisg1977's Avatar
take a look at these pages. the first is on rushforths website. take all the measurements that are on the sheet and you can scan it to him in an email and he will get back to you the next day.
http://www.rushforthwheels.com/pdf/Fitment.pdf
and here you can type in all the dimensions of the wheel and tire sizes and it will give you an image with all dimensions including how the tire will look in the wheelwell
http://www.rimsntires.com/specs.jsp
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #7 of 7 (permalink) Old Nov 7th, 11, 04:03 PM
Jon
Good info Steven
JR67RS is offline
