slick fitment - Team Camaro Tech
post #1 of 14 (permalink) Old Aug 17th, 11, 03:18 PM Thread Starter
slick fitment
Hi all
Has anyone ever fit a 28.5 X 10.5 X15 Slick on a 1969 camaro?
I have 8.5 convo pro wheels with 5" bs - I do have my shocks relocated on the inside
A friend is giving me a set of Phoenix 28.5 X 10.5 slicks
Thanks if you can help.
urbs big block camaro is offline
post #2 of 14 (permalink) Old Aug 17th, 11, 03:22 PM
Re: slick fitment
They <<<should>>> fit fine.
68 Camaro~LSx ~all motor
post #3 of 14 (permalink) Old Aug 17th, 11, 03:56 PM
Steve69SS396's Avatar
Re: slick fitment
I ran 28X10 slicks on my '69 with a 10" rim. With a narrower rim the 28.5X10.5 should fit.
Steve69SS396 is offline
post #4 of 14 (permalink) Old Aug 17th, 11, 04:49 PM
.gearhead.'s Avatar
Re: slick fitment
I run them on my '68 and I think a '69 has more room.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #5 of 14 (permalink) Old Aug 18th, 11, 09:05 AM Thread Starter
Re: slick fitment
Thanks everyone - I will have them mounted up and see what happens - I will let ya know later tonight or tomorrow if they fit
post #6 of 14 (permalink) Old Aug 18th, 11, 07:49 PM Thread Starter
Re: slick fitment
close but no cigar
post #7 of 14 (permalink) Old Aug 18th, 11, 08:10 PM
.gearhead.'s Avatar
Re: slick fitment
Sorry I misread it. Mine are 28's.
Now: Boost...
post #8 of 14 (permalink) Old Aug 19th, 11, 04:28 AM
darrell
Re: slick fitment
where are you off--need alittle more back set
97Z4C is offline
post #9 of 14 (permalink) Old Aug 19th, 11, 12:45 PM
Re: slick fitment
Pics ?
wheel size used ?
post #10 of 14 (permalink) Old Aug 19th, 11, 01:51 PM
Re: slick fitment
my 69 is sitting on 29.5-10.5-15 mickey thompsons right now on some old 15x8.5" ansen slots and they are kinda tight but they fit. ill try to get some pics up later tonight
BLADE4444 is offline
post #11 of 14 (permalink) Old Aug 19th, 11, 02:48 PM Thread Starter
Re: slick fitment
well they kinda fit on the drivers side but I think they would have rubbed the outer wheel well
(only had maybe 3/16 of room on both sides) - and the passenger side was hitting on the inside, of course I could have added a spacer but I really think its just to tight - and I forgot to mention I already had the quarters rolled when I had the car painted - I think I will just buy some Hoosier 28X10X15 they say sec width is 11.7
Do you all use tubes when running slicks?
But for the next two races I am going to throw my buddy's 26X10 Mickey's on it until I place the order.
post #12 of 14 (permalink) Old Aug 19th, 11, 05:00 PM
.gearhead.'s Avatar
Re: slick fitment
Tubes - yes.
Now: Boost...
post #13 of 14 (permalink) Old Aug 19th, 11, 05:12 PM
Re: slick fitment
With slicks and low tire pressures....it's always a good idea to run tubes...get a little sideways and lose a bead = not good
post #14 of 14 (permalink) Old Aug 20th, 11, 06:50 PM
Dana
Re: slick fitment
I once tried a set of 10.5 x 28 Hoosiers on a 8.5 inch 4 7/8 bs on my 69. Cleared the stock wheel wells. Depends on the tire manufacturer. By the way, my cars (and any I've been around) always hooked much better on a 10 inch wheel and a 9 inch tire than a 10.5 tire on a narrower wheel. Always ran quite a bit quicker without tubes,also.
RSCopo is offline
