17 inch wheels problem - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 18th, 11, 01:41 PM Thread Starter
jp
I put a set of boyd crown jewels on my camaro i just finished up. I have 2 inch drop springs in front and 17x8 rims with with 4 inch backspacing and 215 size tires. My problem is rubbing on the outer lip. Is there a closer spindal, smaller tire work or any suggestions. The rim has been discontinued and want to try to keep the look or does someone know where to get these still in 17x7 width?
shovelluv is offline
post #2 of 4 (permalink) Old Aug 18th, 11, 01:50 PM
Kevin
Re: 17 inch wheels problem
I thought I came across that size at summit. You might check there.
Good luck
[U]1969 cloneish Z28
350,9.6 comp,Vortec heads,Crane 274ho6,rpm air gap,Flowmaster
HEI,Holley 600 DP,4 speed 3.11 first,Hotchkis suspension,3.08 rear... need posi.
hpcam is offline
post #3 of 4 (permalink) Old Aug 18th, 11, 01:52 PM
Kevin
Just checked, here ya go.
http://www.summitracing.com/parts/ARE-BCKOA7765/
hpcam is offline
post #4 of 4 (permalink) Old Aug 18th, 11, 02:06 PM Thread Starter
jp
Called summit yesterday. All out of 5 x 4 3/4 bolt pattern.
