Torque Thrust II Fitment 3.75" BS - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 11th, 11, 06:06 AM Thread Starter
For my 67, got a good deal on a set of 4 TT II's that are 15 x 7 with a 3.75" backspace and 235 60R15 tires. Standard drum brakes and new 6308 Moog front springs.
Will they fit with no rubbing?
Another67 is offline
post #2 of 9 (permalink) Old Sep 11th, 11, 10:04 AM
67 Camaros Rock
Joe Harrison's Avatar
Re: Torque Thrust II Fitment 3.75" BS
15x7 with 235/60/15 front and rear with the backspace you have.
I think your good to go with the rear but might get a rubbing on the front. My rear is empty and car is gutted, front has enngine and trans only.
These are loners because I thought of buying them.
This is what I went with for a wheel. 15x8 for the rear 4.5 inch back space witha trial fit 275/60/15 (going with 255/60/15 BGF TA) and the front 15x7 with 4.25 back space. no pics of this one, I will be going with 235/60/15 BFG TA.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #3 of 9 (permalink) Old Sep 12th, 11, 07:57 AM Thread Starter
Thanks Joe, the pics really give me a good idea of what it might be and you are right, the front might be a problem, looks like they might even stick out beyond the fender lip?
Just curious, what springs do have in the front?
I just put on Moog 6308 springs as recommended by David Pozzi and with my current 15x7 wheels with 4.00 BS and 215/65R15 tires it sits pretty good.
I now have 255/60R15's in the rear
I am thinking the front wheels with 3.75 BS might work but I might have to go to a smaller front tire?
Have Rallye wheels now, just looking for a change.
Thanks again,
post #4 of 9 (permalink) Old Sep 12th, 11, 05:32 PM
Jeff
Not sure if this helps or hinders, but I have TT II's 17X8's in front with 225/50 and they fit with 4" of backspace. I installed the DSE upper control arms so it changed things a little. I lowered it 2" and really had to bring the top camber in but it works. Heck, I only drive 100 miles a month so the tires should last 10 years...lol.
-shoe
Current Projects - See my albums
68 Coupe Restomod (7-2010 to ???)
67 RS/SS Convertible project (8-2007 to ???)
Old
67 SS 396 Coupe (sold 7-12), 68 SS 350 (sold 2-12), 68 383 stroker (sold 10-09), 68 SS 350 TPI (sold 2006), 69 SS 350 (sold 1987), 68 327 (1980 Bench seat column shift), 89 RS (son totaled), 88 IROC (son totaled), 76 LT1 (roommate wrecked)
shoe is offline
post #5 of 9 (permalink) Old Sep 12th, 11, 06:12 PM
67 Camaros Rock
Those pics are with QA1 coil overs on the front. I have hotchkiss springs on the front now and I have my hotchkiss springs in the rear in the pics with the black primer on top and the 275 fit.
Yes I think the tire sticks out alittle in the fender but have seen 225 and 215 60 15's on these and they work fine.
With my hotchkiss springs in I had Vett Rally 15x8 with 4 inch back space in the front and rear with 235/60/15 and had very slight rubbing under hard bumps or dips in hilly roads on the outer part of the upper fender lip of the wheel house.
This is a pic. Hotchkiss springs in front....stock original 67 mono leaf spring in the rear.
-Mark Donahue
post #6 of 9 (permalink) Old Sep 13th, 11, 08:37 AM
Russ
I'm running 15x7 TT-D's with 3.76BS and 225/60's up front with Hotchkis 2" drop springs and my wheel wells are full. With the drop springs I don't think I could get 235's to fit.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #7 of 9 (permalink) Old Sep 14th, 11, 09:21 AM
Hotchkis
Steve – The 3.75” back space wheels are going to be close up front, those sizes are common and fit other GM’s better. The better fitting wheel for the front is a 4.5” back space with a 235 and 4.75” with a 255.
Hotchkis is offline
post #8 of 9 (permalink) Old Sep 14th, 11, 06:59 PM
Terry
Here's a pic of my '68 with TQ Thrust "D"'s 15x7 and BFG's 225/60x15 front and rear. Plenty of room. CCP frt 1" drop springs, and 1 1/2" drop Hotchkis rear leafs. 235/60x 15's could rub on the front.
Both optimists and pessimists contribute to society. The optimist invents the automobile, the pessimist seat belts, head rests, disc brakes, and air bags.
IRON MAN is offline
post #9 of 9 (permalink) Old Nov 10th, 11, 05:23 PM Thread Starter
OK so I got another new deal on some Torque Thrust II's for my 67
15x7 front with 3.75 backspace and 215 65R15 tires with new 6308 springs that lowered it 2 inches from original
15x8 rear with 3.75 backspace and 235 60R15 tires
Front fits good with no rubbing and no issues at all
Rear fits good with no issues but if I had a choice again I would go with the 4 1/2 backspace and 255 60R15 tires for a better look.
Rear is not lowered with original mono springs and 15PSI in my air shocks
The 235 tires look small because I took off 255's that were on Rallyes
Will try to take some pics
