Backspacing - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 22nd, 11, 07:22 PM Thread Starter
terry
Backspacing
I want to buy 18" wheels to fit a 69. Would like to have 8" in front and 9" in back. The man I am dealing with said the front should have 5.25 backspace and back should have 5.75 backspace. I don't want them to rub but I don't want them too far under the fender either. Sure could use some help. Thanks
tkz69camaro is offline
post #2 of 6 (permalink) Old Sep 22nd, 11, 07:45 PM
joseph l clance
joe clance's Avatar
Re: Backspacing
Dont go over 5.5"BS on the rear. you'll run the risk of rubbing the rear inner rails. fronts on an 8" wheel, you should be good between 5.25 to 4.75BS. however, you may also rub the inner frame rails at full turn. assuming you 'll run a 35-40 series tire with the proper width for the rims.
joe.c
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
post #3 of 6 (permalink) Old Sep 22nd, 11, 09:33 PM Thread Starter
terry
Re: Backspacing
Joe, would 5" backspace work on both front and rear or should front be less? Thanks
post #4 of 6 (permalink) Old Sep 22nd, 11, 09:52 PM
Steiner
Re: Backspacing
5.5" on a 9" rim should be perfect on the back. Less than that might put it too close to the lip. As said, 8" fronts do well at 4.75" minimum (what I run).
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 6 (permalink) Old Sep 23rd, 11, 04:07 AM
joseph l clance
joe clance's Avatar
Re: Backspacing
If you run 8" wheels on all four corners, 5" bs would work fine and allow you the luxury of freequent tire rotations. Should front be less? only if you want the most tire patch you can get at all four corners. Mixing wheel width and BS front to rear is done frequently on these cars.
As stated above, less BS on a 9" rear wheel can, may , might, maybe not ??? cause rubbing on the outer quarter lip. however, you could roll or cut the outer lip to correct)?
You also can get away with less BS and a wider rear wheel if you are at normal ride height, run a lower aspect ratio tire, and not planning to lower the suspension.
Keep in mind, you cant add to backspacing to a wheel , but you can remove it with wheel spacers (if you get it wrong by a small amount). if you dont get enough BS, you have to modify the outer wheel well to clear outer interference. if you get too much BS, you can add spacers to clear the inner interference. (either way not ideal but the latter is easier).
if it were me and assuming they fit (cant be sure without knowing the mods to the car ):
5.5 BS rear w/ 265 @ 35 tire on 9" wheel
5.0 BS front w/245 or 235 @ 35 to 40 tire on 8" wheel.
all depends what you want the car to do?
joe c
post #6 of 6 (permalink) Old Sep 23rd, 11, 04:26 AM Thread Starter
terry
Re: Backspacing
Thank both of you for helping out. I feel better about it now.
