Difference between back spacing & offset - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 16th, 11, 04:43 AM Thread Starter
Craig
I'm looking at getting bigger rims for the back & want to go to a 17"x 9.5" rim & on the sticky it says that a BS of 5.5 is the go but what is the difference between back spacing & offset.
Craig.
lazyone is offline
post #2 of 5 (permalink) Old Oct 16th, 11, 06:17 AM
Lonnie
Lonnie P's Avatar
Re: Difference between back spacing & offset
Backspacing is the measures distance from the mounting face of the wheel to the rearmost surface of the inside bead. This is good for knowing distances to the suspension etc. It is essentially half of the wheel width, plus approx 1/2" (depending on the thickness of the wheel lip itself).
Offset is the difference between the wheel mounting flange & the center of the tread. Offset is great for comparing 2 different wheels, as you will know where the tire is in reference to the wheel mounting surface.
For example an 8" wheel with zero offset has 4" in either direction from the wheel mounting face. It could have 4-3/8" to 4-5/8" backspacing bepending on wheel thickness.
Years ago backspace was measured at the inner bead, leading to a lot of confusion. I think the main reason for change was the newer cars with positive offset wheels. Now the wheel is closer to the suspension, making this dimension more critical.
Lonnie P is offline
post #3 of 5 (permalink) Old Oct 16th, 11, 07:39 AM
69-Pace's Avatar
This site has great graphics for those of us that need a visual to help understand the difference:
https://www.rsracing.com/tech-wheel.html#backspace
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 5 (permalink) Old Oct 16th, 11, 10:30 AM
DjD
DjD's Avatar
Offset is where the wheels mounting pad is in relation to the centerline of the wheel (+ or - __ mm).
Backspacing is where the wheels mounting pad is in relation to the inner edge of the wheel.
Offset is metric and backspacing is standard measurments... The chart on the link Brian provided is a great cross reference.
...Dennis
DjD is offline
post #5 of 5 (permalink) Old Oct 16th, 11, 12:27 PM Thread Starter
Craig
Thanks Guys
lazyone is offline
