20x10? - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 12th, 11, 07:23 AM Thread Starter
BARTELL
20x10?
Can I get 20x10 wheels under the rear of a 67 with a 12 bolt and multi leafs?
BTELL67 is offline
post #2 of 11 (permalink) Old Nov 12th, 11, 07:29 AM
Andrew
Andrew69's Avatar
Re: 20x10?
Without mini-tubbing the wheelwell I really don't think so.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 11 (permalink) Old Nov 12th, 11, 09:44 AM
Jeremiah
Re: 20x10?
I had 20/8.5 wheels on the back of my 67 when I first bought it and IMO that is the widest you can safely fit. With a 10" wide wheel your going to have the rear excessively high or mini tub it.
I have since replaced the 20/8.5 with 18/9.5 and like the look much better.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #4 of 11 (permalink) Old Nov 13th, 11, 08:07 AM
Jeff
yellow69RS's Avatar
Re: 20x10?
Jerimiah, do you have before and after pics you could post? Bartell has mentioned he doesn't want to ride on rubber bands so it might help him to see those 20's
Jeff
yellow69RS is offline
post #5 of 11 (permalink) Old Nov 13th, 11, 11:17 AM Thread Starter
BARTELL
Re: 20x10?
Yes please. Thanks Jeff!
BTELL67 is offline
post #6 of 11 (permalink) Old Nov 13th, 11, 05:13 PM
Re: 20x10?
Here's 20's on a Hummer...http://www.drollthings.com/?p=2212
markw is offline
post #7 of 11 (permalink) Old Nov 13th, 11, 06:08 PM
Re: 20x10?
I have 20x9.5 on the rear of my 69 with a 12 bolt and multi leafs. They have a 5.5" backspacing and I run 285/30/ZR20 tires with no clearance issues. Here is a pic of the rear.
69 Camaro X44
408ci
Terminator EFI
AFR 195's
XE274H
T56 Magnum
4:10 posi
12 Bolt
bkerns925 is offline
post #8 of 11 (permalink) Old Nov 14th, 11, 11:30 AM Thread Starter
BARTELL
Re: 20x10?
Thanks Bkerns. Looks great! Are those Boss 338's?
No offense, but that is what I call rubber bands. I would like a wide tire and about double that sidewall height. I have all stock suspension and I don't want lack of rubber to add to the rough ride! Been through that before.
BTELL67 is offline
post #9 of 11 (permalink) Old Nov 14th, 11, 05:44 PM
Re: 20x10?
They are Boss 338's. You may be able to add a little more backspacing and get a little taller tire to tuck inside the fender well but it will be really close. I have another .75-1" space between the inner fender well and the sidewall but dont think I would go any wider because my car sits low in the rear. I have my car up on stands at the moment so I took a few pics. They wouldn't upload in my reply so I uploaded them in my album on the forum.
69 Camaro X44
408ci
Terminator EFI
AFR 195's
XE274H
T56 Magnum
4:10 posi
12 Bolt
post #10 of 11 (permalink) Old Nov 14th, 11, 08:42 PM Thread Starter
BARTELL
Re: 20x10?
What size tires?
BTELL67 is offline
post #11 of 11 (permalink) Old Nov 14th, 11, 08:46 PM Thread Starter
BARTELL
Re: 20x10?
What made you choose the Boss 338's? Im stuck bewteen Coy C5 and Boss 338's. Black, Silver, or Gunmetal Gray. Ill have to post some current photos of the car.
BTELL67 is offline
