New 17x8 TT2's will not fit in front - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 15th, 11, 03:41 PM Thread Starter
Jason
I have a 68 camaro I am restoring and I just tried to install my new TT2's I just purchased. My car does have the disc brake conversion and I opted for the 2" lower bracket. My TT2's are 17x8 with 4.75 backspacing mounted on 225/45/17's. It appears my problem is the rim is hitting on the lower tie rod end.
Does anyone know if there is an option or some spacers I can buy as this seems like it should be a simple fix or a common problem as the majority of members have this combo.
Thanks,
Jason
68-327RS is offline
post #2 of 6 (permalink) Old Nov 15th, 11, 04:10 PM
Bobby
Re: New 17x8 TT2's will not fit in front
By 2" lower bracket do you mean drop spindles. If drop spindles I've read that problem is common with that size rim. I guess the best fix is to get rid of the drop spindles and use lowering springs instead.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #3 of 6 (permalink) Old Nov 15th, 11, 04:47 PM Thread Starter
Jason
Yes its the 2" drop spindles. I like the stance of the car and the drop spindles are new as well.
68-327RS is offline
post #4 of 6 (permalink) Old Nov 15th, 11, 05:50 PM
Steiner
Yes it's a common problem but no easy fix if you like your rims to fit. Most people wind up replacing them with standard spindles and 2" drop springs for the same look without issues. There are supposed to be some drop spindles out now that fit right.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 6 (permalink) Old Nov 15th, 11, 06:04 PM
Jerry R.
jr68's Avatar
My set up is slightly different.
I have a 68 with 17x7 TT2's with 4" bs and 225-50 tires.
I used 2"drop coils. I have no rub issues.
You can use your old drum spindles for disc brakes if you machine a little from the upper boss.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #6 of 6 (permalink) Old Nov 15th, 11, 06:34 PM
joseph l clance
joe clance's Avatar
Check if wheel spacers will placce your wheels outward enough to clear the the rod ends.
its the cheapest way to go if it'll clear. you might have place longer wheel studs if you go that route.
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
