Hub Centric Rings? - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 28th, 11, 08:46 PM Thread Starter
Vic
cadmanof50s's Avatar
Send a message via Yahoo to cadmanof50s
Hub Centric Rings?
OK. Tomorrow I will be ordering my new wheels and I thought it would be a good idea to also purchase a set of hub-centric rings.
My new wheels have a bore of 83mm. I can get rings with an outside diameter of 82 mm. This should fit very well.
But what size inside do I need.? I can get a set with outside of 82 mm and inside of 71.5 mm
My car is a '68 with front disks and rear drums. I currently have an original set of 14" rally wheels which fit perfectly over the front and rear hubs.
will rings of 82mm out and 71.5mm inside work?
Thanks!
Vic
Vic Brincat
383 SB, AFR 195 Heads, 670 Holley, Doug Thorley Tri-Y Headers, Lunati "Voodo" roller cam, Weiand 8150 Intake, Scorpion Edurance Rockers, 700r4, Eaton Posi with 3.73 gears, Front Discs, Summit Legend 5 - 15" with BF Goodrich TAs
cadmanof50s is offline
post #2 of 11 (permalink) Old Nov 29th, 11, 04:54 AM
Re: Hub Centric Rings?
Speed has never killed anyone. Suddenly becoming stationary, that's what gets you! Jeremy Clarkson
Headshake is offline
post #3 of 11 (permalink) Old Nov 29th, 11, 06:07 AM
Kevin
KevinW's Avatar
Vic, thanks for the term, I did not know these existed! I will need these for my truck project. I assume you have a way to measure the old rally wheels (which are hub centric) and have the specs for the new wheels to determine the difference.
http://www.summitracing.com/search/D...Centric-Rings/
Kevin
KevinW is offline
post #4 of 11 (permalink) Old Nov 29th, 11, 06:41 AM Thread Starter
Vic
Kevin, there in lies my problem..I don't know the bore size of the old rallys'.
<OK..I was being lazy and hoped someone would know....;-)>
But I will go out to the garage, pull off one of the wheels and get my calipers out.
Here is what I got:
I measure 70.5 mm at the outer edges of the front hub. That leaves 1 mm to spare with the 82/71.5 mm ones I selected below. Should be okay with these....
http://www.summitracing.com/parts/GOR-82-7150/
Vic
Vic Brincat
post #5 of 11 (permalink) Old Nov 29th, 11, 09:11 AM
parkbrau's Avatar
You should get rings that match the exact inside dimensions of the rim and the outside of the hub, which is 70.5. Dont give a MM to spare. I bought the aftermarket rallys from JC whitney and they needed the rings. I found a set on ebay that matched the exact rim dimension and the 70.5 hub dimension. They fit tight.
parkbrau is offline
post #6 of 11 (permalink) Old Nov 29th, 11, 10:08 AM
Kevin
KevinW's Avatar
Why so tight? The 1mm difference is really .5mm when mounted. The lugs should center is well within those limits.
Kevin
KevinW is offline
post #7 of 11 (permalink) Old Nov 29th, 11, 10:52 AM Thread Starter
Vic
1 mm is basically 40 thousands of an inch. Kevin is right, when mounted that thranslates to 20 thousands of an inch on each side.
Also it is important to keep in mind heating and cooling. Hubs often get hot and will want to expnad some...probably not 20 thousands of an inch but some expansion room is needed.
When you look very close at the hub, it tapers out slight where it meets the base of the drum and the disc. That tapers adds at least 1 mm.
Lastly, the ones that I saw had no other option than 71.5 mm. in combination with a 82 outside.
I ordered my new wheels along with these rings and locking nuts. When I get them and have a chance to install, I will post let you know how they and work.
Vic Brincat
post #8 of 11 (permalink) Old Nov 29th, 11, 10:57 AM
Vintage 68's Avatar
Wink Re: Hub Centric Rings?
Vic
... I measure 70.5 mm at the outer edges of the front hub. That leaves 1 mm to spare with the 82/71.5 mm ones ...
Vic
Hummm - my math would say you have 2mm min. "to spare"
You're already 1mm 'off' at the wheel, then adding another 1mm at the hub - then splitting the difference ...
So, you want a hub center ring that either fits the wheel exactly or the hub exactly and is press-fit to the other part - not one to throw in there to rattle around between the two ...
Try - http://www.motorsport-tech.com/ (fixed it)
Go to "Hub Ring" page and check - they do custom for very reasonable $$ also
And go for Aluminum if you plan to use your car in any competition like auto-cross.
1968 Convertible
Some trucks
Vintage 68 is offline
post #9 of 11 (permalink) Old Nov 29th, 11, 11:08 AM
parkbrau's Avatar
All I can say is press on with what you think is correct. My rings are tighter than a ducks a$$, the ring slides over the hub tight...No wiggle. Then fit the rim onto the hub, over the ring..... No wiggle at all...... again tight. I have run them for a while now....up and down the autobahn.
parkbrau is offline
post #10 of 11 (permalink) Old Nov 29th, 11, 02:12 PM Thread Starter
Vic
John and John,
All very good points. Thank you!
I went to the http://www.motorsport-tech.com/ site. And I will defintely keep it as a reference. A set from these guys which will no doubt provide a very good fit is $100.00.
Lets see if my $18.99 set fits snug enough. If not, I will order a set from motosport.
Of course, I am a big believer in "you get what you pay for".
BTW, according to this site, teh '68 Camaro has a hub diamater of 70.3 mm
Vic Brincat
post #11 of 11 (permalink) Old Dec 5th, 11, 12:57 PM Thread Starter
Vic
Update>
Just got my new wheels and the $18.99 hub rings.
I will not be using these rings as the fit is sloppy.
I will be taking Johns' advise and ordering a proper set of rings from:
Thanks guys.
Vic
Vic Brincat
