Rally Wheel Trim Ring - Which is Correct? - Team Camaro Tech
post #1 of 25 (permalink) Old Nov 29th, 11, 04:10 PM Thread Starter
Lloyd
I am trying to determine which rally wheel trim ring is correct for my 4C build date 1969 Z/28. The rings I need are 15" 4 clip style however is the slotted or oval/captured valve stem cutout correct for my car?
Oval / Captured style
Slotted Style
Edgemontvillage is offline
post #2 of 25 (permalink) Old Nov 29th, 11, 04:20 PM
69-Pace's Avatar
Re: Rally Wheel Trim Ring - Which is Correct?
top one is correct for 69
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 25 (permalink) Old Nov 29th, 11, 04:30 PM Thread Starter
Lloyd
Thanks for responding however how do you know this is the correct trim ring?
post #4 of 25 (permalink) Old Nov 29th, 11, 04:35 PM
69-Pace's Avatar
Ah I was afraid you would ask that question. There are two correct numbers. Before recall and after recall. In the blurb below the superseded number is the part number before recall - the design with the "suicide" clips. The first number is the replacement design number with the improved and safer clip design.
So we have this info for 2 1/4" rings:
3934892(sup by 475020 inside clips) - 1969/ALL WITH 14 IN STD WHEEL /OPTION P06
3934892(sup by 475020 inside clips) - 1969-71/ALL WITH 14 IN RALLY WHEEL /OPTION ZJ7/ EXC 350 /300 HP/ AND 396 ENGINE
And we have this info for 2 3/4" rings
9796919 (sup by 2251945 ring clips) - 1969-70/ALL WITH 14 IN RALLY WHEEL /OPTION ZJ7/ WITH 350 /300 HP/ AND 396 ENGINE
9796919 (sup by 2251945 ring clips) - 1969/ALL WITH 14 IN SUPER SPORT WHEEL /OPTION N66/
To me that reads that for the 69 Camaro the 3934892 ring was used by standard 14" wheels and rally wheels EXCEPT for the 350/300 and 396 engines. Which means to me non-SS rally wheels, ergo 14x6 rallys.
And the 9796919 ring was used on the N66 rim (SS wheel) AND option ZJ7 rally WITH 350/300 and 396 engines (SS models!)
from this thread:
https://www.camaros.net/forums/showpo...6&postcount=32
https://www.camaros.net/forums/showpo...22&postcount=4
And
15 inch Z-28 thread is here but don't know if the GM part is ever mentioned.
https://www.camaros.net/forums/showth...nch+trim+rings
69-Pace is offline
post #5 of 25 (permalink) Old Nov 29th, 11, 05:28 PM Thread Starter
Lloyd
Brian, thanks for such a comprehensive reply. I note that all the part number references are for 14 inch wheels where the Z/28 YH rally wheel is of course a 15 inch diameter. In the "15 inch Z-28" thread link "Zuma", in Post #7, he provides 2 pictures of what he describes as an original trim ring on a YH wheel that clearly shows the oval / captured stem cutout. I question if this is reliable information because if you click through to the link in his signature to pictures of the '69 he restored, its an SS not a Z/28 and tires in the photos match those in the posting. There's no way to tell if these are 14" or 15" wheels/tires and importantly if they are original Z/28 15" trim rings or something else. Have I missed something?
post #6 of 25 (permalink) Old Nov 29th, 11, 08:36 PM
Jeff
Dunno any part numbers, but I think this is the correct look for a 1969 Z/28. The outside lip has a double ridge and the valve stem hole is oval with flat sides. (Photo shows a 15" YH wheel.)
JeffD is offline
post #7 of 25 (permalink) Old Nov 30th, 11, 04:59 AM
Kevin
KevinW's Avatar
Jeff's pic is more correct (but hard to really see the details). The first pic in the OP is the 14" SS rally edge treatment, the 2nd pic in not a 69 Camaro, but has the correct step down edge treatment. For 15" rallys you are looking for a oval hole, step down edge ring.
This is the 14x6 ring, showing the step down edge treatment. The 15" edge treatment is very similar.
Kevin
KevinW is online now
post #8 of 25 (permalink) Old Nov 30th, 11, 06:19 AM
69-Pace's Avatar
Yeah I'm sorry since I have 14 inch wheels I lost track of the final outcome for the 15 inch series. The GM parts catalog for 72, and 75 that these part numbers came from should have all the GM wheel sizes. Ask and they should be able to pull that info for you. If I find my uncles 72 catalog in the garage - suspect a buddy"borrowed" it - I'll post it for you this weekend. But I'm sure someone will beat me to it.
The long and the short as to the "correct" style and design of the Rally wheel trim rings for which application and year is mute after the mandated safety recall as GM only produced one hole shape and style and this replacement part became the standard part for all lines. That is just the way GM handled it. They made different depths and diameters but all have the same design. If you went in for any service while the recall was active, the dealer ripped off the suicide rings and slapped on the replacement and billed GM. It was easy money in their pocket. So in reality it doesn't matter 40 plus years later if the hole or step is correct as original show-room floor unless you have a show car.
The beauty is that once installed those two features disappear into the magic that the stainless rings, chrome derby caps and argent silver rim paint combination does to the human eye. No one except a competition judge is going to say hey you have the wrong rings.
Just buy quality as the cheapo China rings are notorious for loosing luster after a few months. Quality NOS pre and post recall design rings in all sizes hit flea bite all the time if you are looking for that, and if you catch a sleeper you can spend less then a grand on them, but quality perfect used ones for cheaper then Ricks also hit all the time. I picked up a set of 4 for a couple of hundred a while back for a buddy's ride while he serves over in the sandbox. One small area that buffed out and they are perfect post recall.
Hope that helps you find peace in the trim ring patch.
69-Pace is offline
post #9 of 25 (permalink) Old Nov 30th, 11, 09:01 AM Thread Starter
Lloyd
Good advice Brian. On your point "So in reality it doesn't matter 40 plus years later if the hole or step is correct as original show-room floor unless you have a show car.", my car was Legends judged in 2007 and I am working on correcting some areas where there were point deductions so "correct and original" is my focus. As you can appreciate its a tedious process.
post #10 of 25 (permalink) Old Nov 30th, 11, 09:03 AM Thread Starter
Lloyd
Very helpful, thanks
post #11 of 25 (permalink) Old Nov 30th, 11, 10:30 AM
This is a 4 clip 15" trim ring.
ID:	25665   Click image for larger version
msicks is offline
post #12 of 25 (permalink) Old Nov 30th, 11, 10:35 AM
and on a wheel
msicks is offline
post #13 of 25 (permalink) Old Nov 30th, 11, 11:36 AM Thread Starter
Lloyd
Originally Posted by msicks View Post
and on a wheel
Thanks, good photos.
post #14 of 25 (permalink) Old Nov 30th, 11, 01:09 PM
69-Pace's Avatar
Ah yes I can understand that you have some digging and hunting to do. Did you get the correct original part number yet?
69-Pace is offline
post #15 of 25 (permalink) Old Dec 1st, 11, 09:30 AM Thread Starter
Lloyd
Brian, no confirmed part number as yet however I wasn't aware the GM part # was stamped anywhere on the trim rings?
