Rear wheel size question w disc brake - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 5th, 11, 03:02 AM Thread Starter
Marc
Hi!
I am sorry of this has been asked already but reading previous posts on combos I didn't find information on this so here I post my question :
1968 Camaro with CPP big brake kit supposed to
- no offset change front
- +3/8 offset (bringing wheel more outside) on the rear
I want to buy :
VWW V45
Front 2 x 17x8 backspace 4.75"
Rear 2 x 17x9,5 backspace 5.5"
On all the pictures posted there is no info on the brake set up and changes of hubs position in reference to original drum set up.
My question is :
Considering my 3/8 offset at the rear, will this rear wheel 9.5J and 5.5 BSP fit nicely with no rubbing with a 275 tire?
Marc
Camaro 1968, propane 327ci, Big Brake, Hotchkis, T56
Marc is offline
post #2 of 3 (permalink) Old Dec 5th, 11, 05:37 PM
joseph l clance
joe clance's Avatar
Re: Rear wheel size question w disc brake
you may have to roll/trim the outer wheel well. you will need to maintain the 5.5" b/s. more b/s will run close to the inner wheel well. i run the cpp big brake with 18X10 @5.5 b/s with a 285x 35 tire with 2" drop springs. i had to trim the outer wheel well to eliminate rubbing in bump.
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
post #3 of 3 (permalink) Old Dec 7th, 11, 04:52 AM Thread Starter
Marc
Thanks for your answer. As my wheel is narrower and I will put a thinner tire it may be allright for me..
By the way are you glad of your CPP kit?
No lateral runout on rotors when it begins to wear? No vibration issues?
Regards
Marc
Marc is offline
