Wheel size recommendation - Team Camaro Tech
post #1 of 12 (permalink) Old Dec 7th, 11, 05:40 PM Thread Starter
Dean
islanddean's Avatar
The tires on my Camaro are 215/65R 15. What size wheel would look best?
15 x 8
15 x 7
15 x 6
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
islanddean is offline
post #2 of 12 (permalink) Old Dec 7th, 11, 09:31 PM
Bobby
Re: Wheel size recommendation
I have that size tire on the front, The car came with 15x6 in front and I changed to 15x7, I like it better. 8" rim might look too big for that tire. I run 15x8 in the back with 255/60x15.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #3 of 12 (permalink) Old Dec 8th, 11, 04:24 AM
1st 67 SS/RS's Avatar
Luwi67, Did you mean the car came from the factory with the 14x6's not 15's? I think the 15x7 look good as well. With the 15x8's, you will have to worry about getting the correct backspacing so it doesn't rub (if the car is lowered and turn sharp) or hits on the steering linkage.
67 Vert RS/SS 350 4 SP
1st 67 SS/RS is offline
post #4 of 12 (permalink) Old Dec 8th, 11, 06:18 AM
Bobby
No, sorry Scott, I meant it had the 15x6 with 215/65r from the previous owner and I just swapped to a 15x7 rim with the same tire.
Dean, I think 15x7 with 4 1/4" backspace is a safe choice for the front and 15x8 with 4 1/2" backspace for the rear.
67 Camaro 350
M20 4spd console,
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #5 of 12 (permalink) Old Dec 8th, 11, 06:37 AM
Robert
Talking Re: Wheel size recommendation
15 x 8
15 x 7
15 x 6
15 x 7 looks the best IMO!
rsb0719 is offline
post #6 of 12 (permalink) Old Dec 8th, 11, 06:40 AM
Fred
77thor's Avatar
Yes, 15x7
77thor is offline
post #7 of 12 (permalink) Old Dec 8th, 11, 10:47 AM Thread Starter
Dean
islanddean's Avatar
Thanks for the advice guys! I've never seen what a car looks like with the various size wheels on so it's difficult for me to know what I'm wanting.
MLK
post #8 of 12 (permalink) Old Dec 8th, 11, 11:25 AM
Bobby
Here is a bunch of 67s:
https://www.camaros.net/forums/showthread.php?t=153144
If you look on my profile there is a pic of my 67 with the sizes I posted earlier.
67 Camaro 350
M20 4spd console,
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #9 of 12 (permalink) Old Dec 9th, 11, 08:49 AM
Russ
15x7's front and rear. 3.76BS. 225/60 in front, 245/60 in rear. Next time I'll put 255's in the rear as plenty of room. Hotchkis 2" springs in front, 1.5" leafs in rear + 1 " block.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #10 of 12 (permalink) Old Dec 10th, 11, 03:56 AM
Bruce
I have 15 x 8 Corvette rallys with 67 flat caps on my 69. 245/60 on the rear and 225/60 BFG RWL on the front. It really makes the car look muscular and I have no rubbing problems and get comments all the time. I have another 69 with "7" s and get no comments as it looks stock like the z's were.
The Camaro Guy is offline
post #11 of 12 (permalink) Old Dec 10th, 11, 05:56 AM
Lonnie
Lonnie P's Avatar
This is a 215/65 on a 15x7 wheel.
This would be the preferred size for that tire, plus it fits well under the front of the car.
Lonnie P is offline
post #12 of 12 (permalink) Old Dec 10th, 11, 09:01 AM
DjD
DjD's Avatar
Using tire rack . com and looking up the tire size and spec's for a tire they list what wheel size the tire is designed for. Your 215/65 15 is made for 6" - 7.5" wheels. Typically the widest wheel the tire is designed for will give the best performance and the tire will look slightly wider than it does on the narrower wheel.
...Dennis
DjD is offline
