Lug nut issue - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 15th, 11, 08:09 PM Thread Starter
Brent
Lug nut issue
Was putting on my new wheels today and got to the last one, which is a uni lug of course and I couldn't get the lug nut on. Took it off and looked the stud and one of the threads was slightly damaged, but enough to stop the lug nut. How should I handle this? I Know an Impact wrench would get it on no problem.
tbd67 is offline
post #2 of 4 (permalink) Old Dec 15th, 11, 08:40 PM
Shane
Re: Lug nut issue
Maybe get a tap and die set and run the correct die over it. It should clean up the threads. If not, replace the stud.
stea is offline
post #3 of 4 (permalink) Old Dec 16th, 11, 02:34 AM
Re: Lug nut issue
Yes, run a tap through it to clean it up or install a new one.... nothing worse the gulled threads and rounded off nuts when working on you car.
68 Camaro~LSx ~all motor
post #4 of 4 (permalink) Old Dec 16th, 11, 03:40 AM
TDW
Tony
Re: Lug nut issue
A thread file will clean up the threads on a stud.
http://www.bing.com/shopping/kd-2249...tool&FORM=HURE
TDW is offline
