Looking for some advice - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 28th, 12, 06:08 AM Thread Starter
I would like to install Bear Disc brakes all the way around on my 69.
Because the brakes are bigger then stock I am guessing the new rim size show be 17" x 7"
Would I need to use low profile tires with this set up to eliminate fender rum?
Thanks,
Schoon
Schoon
SCHOON is offline
post #2 of 3 (permalink) Old Jan 28th, 12, 06:26 AM
Bobby
Re: Looking for some advice
You can calculate the right tire size by using the formulas in this article:
http://www.tirerack.com/tires/tirete....jsp?techid=46
It's an easy read.
Also check out the sticky https://www.camaros.net/forums/showthread.php?t=153274
And see what the other guys are running, most will give you the set up as far as suspension and brakes along with a pic.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #3 of 3 (permalink) Old Jan 28th, 12, 08:02 AM Thread Starter
Thanks!
Schoon
SCHOON is offline
