Which tire? - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 28th, 12, 07:51 PM Thread Starter
Jeff
Which tire?
Basically the car is only used for street use but I do want a tire thats decent with traction and can be used at the strip once in awhile with good results. Heres the few I was considering but want to hear your advice or other suggestions.
Sportsman Pro - Biased ply
29X15.50-15LT
32lbs
Tread width - 12.7"
Sportsman Street Radial
29X15.00R15LT
42 lbs
Tread width - 13"
ET Street Radial
P325/50R15
37lbs
Tread width - 11.6"
1967 Camaro RS :
461 LS6 BBC
Super Cased Muncie M22Z
12 bolt Posi
jjgrizz73 is offline
post #2 of 11 (permalink) Old Jan 29th, 12, 04:42 AM
Re: Which tire?
I only have dealings with MT DR's and McCreary's......both of which offered decent DRY traction...wouldn't get caught on a wet road or it the rain...just the morning dew had me pucker one morning
MT DR's have a tread ware rating of 0
68 Camaro~LSx ~all motor
post #3 of 11 (permalink) Old Jan 29th, 12, 07:14 AM Thread Starter
Jeff
Re: Which tire?
I currently have the N50 Sportsman I on my car (also has a 0 tread wear haha) and they are ok. Haven't had them to the strip but they do spin quite easily with 20psi on the street. Car is pretty stable though.
1967 Camaro RS :
461 LS6 BBC
12 bolt Posi
post #4 of 11 (permalink) Old Jan 29th, 12, 07:42 AM
Jon
Re: Which tire?
I ran the MT SSR. They had decent traction but I hated the flame tread pattern. I will say MT dose have there sizes correct. What they measure is what you get.
JR67RS is offline
post #5 of 11 (permalink) Old Jan 29th, 12, 07:46 AM
Bobby
Re: Which tire?
Do you have any traction control devises to help plant the tire?
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #6 of 11 (permalink) Old Jan 29th, 12, 07:53 AM
Dave C
Re: Which tire?
I have the sportsman pro on my car 31.5 18 15 and would not buy them again....I know alot of people like the et streets....
PRO.ST69orange
post #7 of 11 (permalink) Old Jan 29th, 12, 08:00 AM Thread Starter
Jeff
Re: Which tire?
The rear of the car just consists of multi leafs and Caltracs.
1967 Camaro RS :
461 LS6 BBC
12 bolt Posi
post #8 of 11 (permalink) Old Jan 29th, 12, 08:03 AM Thread Starter
Jeff
Re: Which tire?
I've heard some mixed things about the pros...I however heard a lot of great things about the ET Streets, wish they came wider than 325's though.
1967 Camaro RS :
461 LS6 BBC
12 bolt Posi
post #9 of 11 (permalink) Old Jan 29th, 12, 01:27 PM
Matt
Re: Which tire?
I just got a pair of 315/35/17 Nitto NT05Rs... dont have them on yet but heard they were even better than the MT or Hoosier drag radials.
'69 Camaro 350 / T56 Magnum / 10-Bolt
Built rear & 4-link coming soon...
6D9 Matt is offline
post #10 of 11 (permalink) Old Jan 30th, 12, 12:09 PM
Greg.
Re: Which tire?
If you want a street tire with some bite, I used these back in the 80's
and they were the best you could buy then and I think now for double purpose tires. IMHO
SUMMIT # COK-72146 Pro-Trac Bias N50-15 RacingProfile # 18050 SKU 72146
- Rims: 8”-12” Tread Width: 11.30” Tread Depth: 12/32 Cross Section: 12.65” Diameter: 27.87”
and they have larger sizes !
I heard that the M/T Sportsman Pro/ET Street Rads were not good in the rain !
Because of the room in my car's stock wheel Fender Wells I run the M/T Sportsman S/R Radial Tires
28'' x 12''R x 15''LT SUMMIT # MTT-6641 on the street and then change them for the following for racing;
A. RIM for Strip = Weld Draglite 90-Series 15” x 8” BC= 5x4 ” BS= 4.5”
Rubber for Strip = M/T ET St Radials # 3753R 275-50R-15
Tread Width: 10" / SideWalls Width: 11.3" - Diameter: 26.1"
B. RIM for Strip = Summit Fast 5, cast-alum1-piece, 15" x 8" BC 5 x 4 ” BS 4.5”
Rubber for Strip = M&H MuscleCar dot DragTireMSS-001 Bias-Ply 275/60/15
Tread Width: 10" / SideWallWidth: 11.7" Dia: 28.2”
Hope this helps !
Greg.
67 Chevelle Malibu SS Cdn
Born 283 PowerGlide A51 Option
Reborn 1st time as 327 Th400
Reborn 2nd time 468 Th400 3.55 Rear Gears
Best 1/4 in street dress
60Ft = 1.788 / ET = 12.388 / MPH = 109.091
Kirk's67SS is offline
post #11 of 11 (permalink) Old Jan 30th, 12, 04:59 PM
Greg.
Re: Which tire?
M/T site doesnot list that tire . I think they stopped making them ?
Do know who still stocks/sells them ??
Greg.
