Help on front and rear wheel size! - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 12th, 12, 06:44 PM Thread Starter
Guillermo
I have a 1967 camaro and was looking into purchasing the Billet Specialties Street Lite wheels. I want to put on some 17" wheels front and back. I have front disc brakes and rear drums. I was looking at Summit and they have these: http://www.summitracing.com/parts/BSP-RS037956155N/. I found these for the front http://www.summitracing.com/parts/BSP-RS037706140N/. Not sure of these will fit correctly. I am planning on lowering the rear 2" or 3" and the rear is not mini tub. The front will be lowered 1.5". Any help or suggestions would be appreciated.
gizcamaro is offline
post #2 of 6 (permalink) Old Feb 14th, 12, 05:11 AM Thread Starter
Guillermo
Re: Help on front and rear wheel size!
Not sure if these http://www.summitracing.com/parts/BSP-RS037956155N/ will fit better tucked in the rear. Any opinions or recommendations?
post #3 of 6 (permalink) Old Feb 14th, 12, 06:49 AM
This is what I put on my stock 68 with front disc and rear drum. No rubbing issues what so ever. My future plans are to lower the front 1.5 and the rear 2.0 and best I can tell there is plenty of room to do so. The wheels are the TT2's with Nitto 555 tires.
Went with the 17x7 4.0 bs with a 235/45 for the fronts
Went with the 17x8 4.8 bs with a 255/45 for the rears.
Sooner_Fan is offline
post #4 of 6 (permalink) Old Feb 14th, 12, 12:14 PM Thread Starter
Guillermo
I think the front 17X7 with 4"backspace should be fine. The rear is what I worry about. Not sure if the 17X9.5 with 5.5"backspace will fit or if the 17X9.5 with 5" will work better. I want a wider tire in the rear.
post #5 of 6 (permalink) Old Feb 14th, 12, 12:34 PM
You may want to browse these 43 pages and see if you find any good info.
https://www.camaros.net/forums/showthread.php?t=100853
post #6 of 6 (permalink) Old Feb 14th, 12, 01:53 PM
Dr. Feelgood
5" b/s in the rear on a 9.5" wide wheel is not enough,you'll be hitting the outer fenders...
Plus,it'll be tough to squeeze a 9.5" wide wheel on a 1967-8,a 9" wheel is really maxing it.
Contact my buddy Jon Henson over at [email protected] that should be up and working by now...tell him I sent you and he'll take care of you.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
