15x8 ralley with 5" backspace for a 69 - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 31st, 12, 06:47 PM Thread Starter
Randy
I got a chance to buy repo SS wheels (15x8) with a 5 inch backspace...
Will these fit a 69 Camaro on just the back.? Thanks
rsgt is offline
post #2 of 4 (permalink) Old Apr 1st, 12, 04:44 AM
Re: 15x8 ralley with 5" backspace for a 69
Probably not, but the tire size will also come into play.
want1 69 is offline
post #3 of 4 (permalink) Old Apr 1st, 12, 04:50 AM
I had them on my 69 but it had a rear end from a 70's camaro which is 1" longer than stock. I had a 275 wide tire on it and the shock just cleared by about 1/2".
If your rear end is the stock length best thing would be to check out what clearances you have now with the current back spacing and go from there.
schnide is offline
post #4 of 4 (permalink) Old Apr 1st, 12, 04:57 AM
Andrew
Andrew69's Avatar
My 8" rear wheels have 4.75" back space and the 255 tires are centered for maximum clearance. I believe a tire with any width will rub the frame area unless you adjust the wheel out with a spacer.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
