275/45/18 will they fit? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 3rd, 12, 05:41 PM Thread Starter
Will they fit on a 68 camaro? I will be running Hotchkis leaf springs and probably 18x9 rims or so.
Thanks, erik
67 Camaro Pro Street, 540 Bill Mitchell Merlin big block, Merlin Aluminum heads, Holley 870, hydraulic camshaft, 2" Hooker Super Comp headers, Mallory and Crane ignition system, TH400, 2600 stahl, Ford 9" w/ 4:10 gears and posi.
Erik Beckett is offline
post #2 of 5 (permalink) Old Apr 4th, 12, 04:48 AM
Re: 275/45/18 will they fit?
I run a 285/40/18 which is a 27.1 tall tire and I believe the sectional width is around 11.3" with no problems. THe tire you are looking at is a little taller 28" but I think it is a little bit narrower.
1968 RS/SS 496 Solid Roller, AFR 290, Pro Systems 1000, TKO600, 12 Bolt 4.11's
2001 Pewter WS6 is offline
post #3 of 5 (permalink) Old Apr 4th, 12, 08:10 AM
Matt
Should fit assuming the correct back space on the rims. I run 18x9 Foose Legends with 5.25 BS and 275/40 tire. Had a very slight rub on the inner wheel well but .25" spacer fixed the issue. Remember, it's always better to have too much BS than not enough as too much BS can be fixed with spacers but too little BS is never good.
Matt
zlek131 is offline
post #4 of 5 (permalink) Old Apr 4th, 12, 04:47 PM Thread Starter
My car now has 255/45's and they are 27" tall. I found an amazing deal on 275/45/18's for the rear of my car and they are only 27.7" tall. I know everybody runs 275/40's. I cant imagine 3/16' on each side will make a huge difference. I can raise the car some too as it sits really low anyways.
Thanks, Erik
post #5 of 5 (permalink) Old Apr 4th, 12, 08:57 PM
Brad
Go read this thread: https://www.camaros.net/forums/showthread.php?t=153274
Brad G
1969 Camaro - 406 - 2004R
American is offline
