Wheel Studs - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 5th, 12, 09:09 AM Thread Starter
Wheel Studs
Hi Guys,
I'm in desperate need of a set of new wheel studs, Summit racing sells them much cheaper than rick's or classic Indu. ... I know they're 7/16 20 but do you know the Knurl size to fit stock rear drums and front discs ?
Also is it a good idea to change to a metric thread for convenience in the future instead of the stock thread ?
thanks in advance
kemy is offline
post #2 of 6 (permalink) Old Apr 5th, 12, 10:09 AM
DjD
DjD's Avatar
Re: Wheel Studs
In the USA we have been going metric since the mid 1970's and not ever completed the conversion and probably won't. Being in Egypt it might be an advantage if the metric system is used.
The studs are pressed into the hubs and axles and should not be an issue with drums and rotors.
...Dennis
DjD is offline
post #3 of 6 (permalink) Old Apr 5th, 12, 10:53 AM Thread Starter
Re: Wheel Studs
Thanks Dennis for your reply.
Yes it seems that I will go metric then, my other two camaros are metric also (78 and 94) but do you know the knurl size that would fit a 69 ?
kemy is offline
post #4 of 6 (permalink) Old Apr 5th, 12, 12:29 PM
DjD
DjD's Avatar
Re: Wheel Studs
Dorman part # 610186 is listed as 7/16-20 with a .472" knurl dia. which is 1 1/2" long for a '69 Camaro, Rock Auto www.rockauto.com has them for $.96 ea.
...Dennis
DjD is offline
post #5 of 6 (permalink) Old Apr 6th, 12, 07:37 AM
Royce
Re: Wheel Studs
On stock front disc brakes the stud presses into the rotor. The rear drums, the stud presses into the axle flange.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #6 of 6 (permalink) Old Apr 9th, 12, 03:47 PM Thread Starter
Re: Wheel Studs
Thanks man, ordered the Dormans from Summit for 21.90$ all 20 studs, cannot believe Rick's Camaros price!!! 3.99 each!!
kemy is offline
