69 Camaro with Rally Wheels - Team Camaro Tech
post #1 of 16 (permalink) Old Apr 23rd, 12, 08:50 AM Thread Starter
Rick
I just bought Rally wheels for the back of my 69 15 x 8 with 4.25" back spacing. What size tire will fit with this combo?
Will a 255/16-15?
Thanks, in advance for the help.
The car does have 2" Detroit speed lowering springs.
Rickb69Z28 is offline
post #2 of 16 (permalink) Old Apr 23rd, 12, 08:51 AM Thread Starter
Rick
Re: 69 Camaro with Rally Wheels
Sorry meant 255- 60- 15
post #3 of 16 (permalink) Old Apr 23rd, 12, 09:02 AM
DjD
DjD's Avatar
With the 2" drop you are going to have problems with almost any tire on 15x8" w/4.25 bs wheels.
A 15x7" w/ 4.25" bs is a more usable wheel and probably the most commonly used. A 235/60 will fit with the 2" drop but a 255/60 will be rubbing on the fender lip. The 15x8" with the same back spacing adds 1" to the visual (fender) side of the wheel, you'll need to jack up the rear of the car....
...Dennis
DjD is offline
post #4 of 16 (permalink) Old Apr 23rd, 12, 03:00 PM
Erick
not sure if its any help but my 69 z/28 as a 2 inch drop with stock 15x7 rallys and 245-60-15.
tires do not rub,*not even with 2 passengers sitting in the back
braz28 is offline
post #5 of 16 (permalink) Old Apr 23rd, 12, 03:18 PM
Barry
Send a message via AIM to barryfrise Send a message via Yahoo to barryfrise
Can you return or exchange the rims? I have 15x8 rally's with a 5" BS on my 69 and am using 255/60-15 tires. I have the Hotchkis 1.5" drop leaf springs and everything fits nice with no rubbing or clearance issues. I was also able to re-use the trim ring from my 15x7 wheel on the 15x8 too.
barryfrise is offline
post #6 of 16 (permalink) Old Apr 23rd, 12, 04:53 PM Thread Starter
Rick
Thanks guys, The place that sold me the rims told me these rims will fit with a 255-60-15 but now I am not so sure I believe him. Makes me scared to mount tires on them. I am afraid if I mount tires on them and dismount he wont want to take them back
post #7 of 16 (permalink) Old Apr 23rd, 12, 05:27 PM
DjD
DjD's Avatar
Just mount a bare wheel carefully to the rear axle and use a straight edge (24" level works well) across the wheel from rim to rim and up to the fender lip. Remember 60 series sidewalls bulge out from the wheel and 255's will buldge more than 235's.
...Dennis
DjD is offline
post #8 of 16 (permalink) Old Apr 23rd, 12, 07:14 PM
Barry
If you mount tires on the rims they won't take them back, at least that's Wheel Vintiques policy. I did what Dennis suggested with my 5" BS wheels, carefully mounting them without tires. I then used a 1x4 turned sideways as my straight edge giving me 3/4" beyond the edge of the wheel. Pushing that beyond the wheel diameter up into the wheel well gave me an indication as to whether I had clearance or not. A 255 tire will bulge 1/2" beyond the edge of the rim, so if the 1x4 fit I was going to be safe.
post #9 of 16 (permalink) Old Apr 24th, 12, 04:27 AM
Bruce
I have 15x8 on all 4's with 245-60 on the rear and 225-60 on the front with stock height and have no rubbing issues on my 69. The rears fit inside the wells with no problem with a load. The problem will be with the fronts when you drop it. Put 7's on the front.
The Camaro Guy is online now
post #10 of 16 (permalink) Old Apr 24th, 12, 05:41 AM
DjD
DjD's Avatar
What's your back spacing?
...Dennis
DjD is offline
post #11 of 16 (permalink) Old Apr 24th, 12, 03:42 PM
Eric
Will a 255/16-15?
Wouldn't 15x8 4.5 backspace work? That's what I have w/255/60 15, but mine's not lowered so I can't say for sure,but I think you'd be O.K.
'69 Camaro, w/'67 L30 327 .030, L79 cam, 700DP, M20, 3.73 12 Bolt
L30 327 is offline
post #12 of 16 (permalink) Old Apr 25th, 12, 04:53 AM
Bruce
The rally wheels I have on my 69 are GM off a 77 Carvette that I bought from the guy in 1979. . . .so whatever stock 15 X 8 Vette wheels are.
post #13 of 16 (permalink) Old Apr 25th, 12, 07:19 AM
Bill
I have 15x8 and 15x7 rear tires are 275x60-15, Fronts 225x70-15 NO rub
Car is low, top of tire is in fender well
Bill
1969 Red SS
496 570 Hp
Tko 600 with 4:10
bcvet is offline
post #14 of 16 (permalink) Old Apr 25th, 12, 09:06 AM Thread Starter
Rick
Thanks for all the input guys. I returned the wheels - FYI 15 x 8 with 4.25 back spacing would not fit my car, no way no how! My car is all original sheet metal. orig rear end housing, never hit.
Hope this helps some one else.
Rick
post #15 of 16 (permalink) Old Apr 25th, 12, 01:00 PM
Erick
get a set of 15x8 4.5 backspace and 255-60-15 will fit perfectly on a 69 camaro
braz28 is offline
