68 Camaro 15x4" tires - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 24th, 12, 10:06 AM Thread Starter
steve
what is the best size for a 15x4 wheel tire size? is 215/70 to big? anyone have any pics of that size? trying to deside between 4" or 6" wide wheels? Thanks
ps1968 is offline
post #2 of 8 (permalink) Old Apr 24th, 12, 10:39 AM
Vintage 68's Avatar
Question Re: 68 camaro 15x4" tires
"15 X 4"
Are these aftermarket 'Drag' rims ???
GM never made or installed a 4" rim on a Camaro.
I don't even know of a 14~15" rim that was that narrow used - only a 13" on some early ChevyII/Novas ...
A 215/70r15 has a MINIMUM rim width of @6" - so if your stuck on that size tire, then your answer is to go 6" minimum.
That tire actually likes a 6.5~7" better for proper sidewall function.
If you plan to use the 4" type, then your stuck with a 'specialty' tire - like a 'drag' style or a 80/82-series metric - 165R15 (think Volkswagen ) would fit
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 8 (permalink) Old Apr 24th, 12, 01:17 PM
Re: 68 Camaro 15x4" tires
I have 15 x 5" Prostars with 205/65/15's.................
68 Camaro~LSx ~all motor
post #4 of 8 (permalink) Old Apr 24th, 12, 01:50 PM
Bill
Calpantera's Avatar
To figure the tire to rim size you divide the rim width by a factor to obtain the proper tire section width for the wheel. For tires with aspect ratios of 50 to 80 the factor is 0.70. For tires with aspect ratios less than 50 the factor is 0.85. For example if your rim width is 4 inches and you want a tire with a 70 aspect ratio, divide 4 by 0.70 giving an answer of 5.7 inches. To convert the result in inches to millimeters, multiply by 25.4 and round down to the nearest odd multiple of five, 5.7 times 25.4 equals 144. Rounded down to 140, the nearest odd multiple of 5.
So for a rim size of 15x4 you would want a 140/70-15. Thats pretty much a motorcycle tire
Calpantera is offline
post #5 of 8 (permalink) Old Apr 24th, 12, 02:21 PM
Paul
Thumbs up Re: 68 camaro 15x4" tires
Originally Posted by Vintage 68 View Post
"15 X 4"
John nailed it. Years ago i ran 15x4 centerlines on the front of my 69 camaro streetcar. The VW tire 165/15 is exactly what i used and they were perfect.
1969 RS/SS DROPTOP is offline
post #6 of 8 (permalink) Old Apr 24th, 12, 03:48 PM
Steve69SS396's Avatar
I have Cooper 165R/15 tires on my car with a 3-1/2" rim.
Steve69SS396 is offline
post #7 of 8 (permalink) Old Apr 24th, 12, 04:32 PM
jeff
1SLOW64's Avatar
i got vw tires from tire kingdom for my 15 X 3 1/2" wheels
1969 X66 PROJECT:
2002 C5 COUPE ELECTRON BLUE SOLD
1987 BUICK GRAND NATIONAL SOLD
1964 CHEVY II 406 SOLD
1SLOW64 is offline
post #8 of 8 (permalink) Old Apr 24th, 12, 07:40 PM Thread Starter
steve
Thanks everyone went with the 15x6. thanks for pics and help.
ps1968 is offline
