17x8 or 17x9.5 wheels to use with 275 tires on 67? - Team Camaro Tech
post #1 of 18 (permalink) Old May 11th, 12, 01:16 PM Thread Starter
Matt
I want to get new wheels and tires for my 67. It has Hotchkis 1.5" drop leafs in the rear. I have looked at the sticky post and see that most people are using 17x9.5 with 5.5 back spacing. I called a shop to get wheels and tires and they said I should use 17x8 with 4.5 back spacing. Which would work and look better? I am planning to buy American Racing Torque Thrust II wheels.
Matt
67 RS, 406 small block, TKO600, Moser 12-bolt (3.73)
MW67RS is offline
post #2 of 18 (permalink) Old May 11th, 12, 01:56 PM
DjD
DjD's Avatar
Re: 17x8 or 17x9.5 wheels to use with 275 tires on 67?
Wheel and tire stores will typically recomend what they have in stock and they don't stock custom sizes. A 275/40/17 is recomended for a 9" - 11" wide wheel. It will most likely fit on an 8" wheel but the sidewall will not work as designed.
...Dennis
DjD is offline
post #3 of 18 (permalink) Old May 14th, 12, 10:01 PM
Pete
Yeah, be careful with wheel companies, if they dont have the size you want the smart (shady) sellers will tell you another size is better. Im running 9 inch wide in the rear with 275. If I could do it over I'd run a 9.5 or a 10.
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
post #4 of 18 (permalink) Old May 14th, 12, 10:35 PM
Steiner
The size they quoted you is fine for a 235, not a 275. I don't even know if you could get the bead to seat right with a low profile 275 on an 8" rim.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 18 (permalink) Old May 15th, 12, 06:01 AM Thread Starter
Matt
Thanks guys. I will keep looking for another dealer. If anyone know of someone that sells Torque Thrust II at a good discount please let me know. I want 17x9.5 for the rear and 17x8 for the front.
Matt
MW67RS is offline
post #6 of 18 (permalink) Old May 15th, 12, 07:00 AM
I run a 275/45/17 on a 17x9.5 TT2 5.5 in BS on my 67, no rubbing ever..
67 Camaro LS1+ tvs2300/4L70E 530 RWHP
64 Corvette Coupe 350/ TKO600
66 Mustang (289/C4)
c6matt is offline
post #7 of 18 (permalink) Old May 15th, 12, 12:11 PM Thread Starter
Matt
Matt, do you mind sharing where you got the wheels? Also, what size wheels do you run on the front?
Matt
MW67RS is offline
post #8 of 18 (permalink) Old Oct 16th, 12, 05:54 AM
Matt. are you sure about the rear size 275/45/17 ? I can't find anyone making that size.
How much room to the inner fender do you have with the 5.5 inch backspace? Would 5.75 inch backspace be better?
Thanks.
Mike68RS is offline
post #9 of 18 (permalink) Old Oct 16th, 12, 03:20 PM
Dr.Ron
Sounds about right. I have been researching wheels/tires myself. Try SFX performance. They have the best prices I have seen, but sometimes specific sizes/backspacings will require special ordering, which tacks on $300-$450 to the cost.
Ron
Dr.Ron is offline
post #10 of 18 (permalink) Old Oct 17th, 12, 10:00 AM
Dr.Ron
American racing doesn't have 17x9.5 with a 5.5" backspacing, unless you special order it as I mentioned above. This increases the price $like $100/wheel.
Found these.
http://www.summitracing.com/parts/ARE-C4057956155/
Dr.Ron is offline
post #11 of 18 (permalink) Old Oct 17th, 12, 01:52 PM
67 Camaros Rock
Joe Harrison's Avatar
Just my opinion I would look at vantage wheel works and get better looking wheel and I think you will spend less. Everything on the street has TT II or knock off of it. Kinda boring looking.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #12 of 18 (permalink) Old Oct 17th, 12, 10:06 PM
ouch
BPOS is offline
post #13 of 18 (permalink) Old Nov 28th, 12, 02:13 PM
Dr.Ron
Originally Posted by BPOS View Post
ouch
Here's my result...Cost was around $1,300 for the wheels & tires.
Ron
Dr.Ron is offline
post #14 of 18 (permalink) Old Dec 2nd, 12, 10:55 AM
i just bought the custom 17 by 9.5 with the 5.5 b.s. mine fits but i have about an inch between inner tire and inner fender. i have a 2nd gen rearend under my car. 2nd gen rearends are one inch wider than 1st gens. i may end up going with a 6.5 inch back spacing and use a 1/4 or 1/2 spacer. as with most camaros my driverside wheel sticks out about a 1/4 to 3/8 futher than the passengerside. i really think a 285 would fit under there with the proper back spacing. i am running the hotchkis tvs and i have about the same rear fender gap as you do. i think mine will settle a little after i drive it. only one wheel came in so i cain t drive it yet. yours looks pretty good by the way. i did roll my rear fender lips. if it rubs on the driverside i may have to order just one wheel with the correct offset for the driverside. if it does not workout i can always just put them on my 71 camaro as that is what they run. so for all yaw running 2nd gen rearends you will need to run a 6 to 6 1/4 inch back space.
black 67 rs, factory power windows, a/c, deluxe interior, rear folding seat, tilt,power front disc brakes, speed warning, upgrades: four wheel disc brakes, factory tune port fuel inj., 700r4 over drive trans, electric cooling fans, 4:11 posi 12 bolt rear end, factory rated 300 hp 327,
airtime is offline
post #15 of 18 (permalink) Old Dec 3rd, 12, 08:29 PM
Jeff
Ron, can you tell us what you ended up buying? I think it looks really good and would be interested in something similar. What type of rims did you end up with, sizes, backspace, etc. Also tire size would be helpful.
Thanks,
Jeff
jmilford is offline
