17/18 staggered wheels and tires size help - Team Camaro Tech
post #1 of 5 (permalink) Old May 18th, 12, 11:35 PM Thread Starter
BARTELL
Hey guys,
67 SS/RS multi leaf all stock. Front is sitting high due to new springs so having them cut once I get wheels.
So I want 17's front and 18x9 or 9.5's in the rear. What are some good tire sizes? I want the rear wheels as wide as I can get and about and inch or two taller that the fronts.
Thanks!
BTELL67 is offline
post #2 of 5 (permalink) Old May 19th, 12, 04:29 AM
Bruce
Re: 17/18 staggered wheels and tires size help
If you go to the Tire Rack site and look at "specs" you will get all the data you need. Make sure you check your backspace. I put 275-40-17's on the back and 255-50-16's on the front as I wanted the same size sidwall on both the front and back. I did a good amount of measuring to get the right tire. Now I have to tell you this was on my c-10 69, but the same process I went through with my Camaro. I have smaller diameter wheels than what you are doing as I don't care for the rubber band tire look on these classics. I have kept the same wheel diameter on the Camaros, 15's, but stagger the tire size. Good luck on what ever you decide.
The Camaro Guy is offline
post #3 of 5 (permalink) Old Jun 24th, 12, 11:03 PM
Pete
18x8 front, 18x9 rear Boyd Coddington Junk Yard Dog 2-piece aluminum wheels, powder-coated in flat black. Toyo Proxes 225/40-18 front and 275/35-18 rear
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
post #4 of 5 (permalink) Old Jun 24th, 12, 11:06 PM
AJ
Pete, your car looks extremely aggressive, love it. Junk yard dogs are still my favorite wheel on first gens.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 5 (permalink) Old Jun 24th, 12, 11:09 PM
Peter
PAZZ's Avatar
Awesome stance and wheel combo.
Any rubbing on the rears, Pete?
PAZZ is offline
