WILL 18x9.5 rub? - Team Camaro Tech
post #1 of 9 (permalink) Old May 26th, 12, 12:05 PM Thread Starter
BARTELL
WILL 18x9.5 rub?
Can I get rear 18x9.5 with 5.5 BS and not rub? 275/40/18. Coy C-5. If I have to roll the fender, will I be able to use my wheel well moldings?
Thanks!
BTELL67 is offline
post #2 of 9 (permalink) Old May 27th, 12, 11:57 AM
Brent
67Rally's Avatar
Re: WILL 18x9.5 rub?
Thanks!
Those will be very close, but yes I think they'll rub, but they'll rub on the inside not the outside.
I have 275/40/18's on 18x9's with 5.25" BS and I would not want them to sit any deeper than they do. Even a 1/4" would be pushing it, which is what the 18x9.5 with 5.5 BS will do.
Before I replaced my rear leafs, one of the rear tires did rub on any decent suspension travel.
67Rally is offline
post #3 of 9 (permalink) Old May 27th, 12, 12:21 PM Thread Starter
BARTELL
Thanks Rally,
I want Coy C-5 flat black. They only come in 18x8 ro 18x9.5. AARRGGHH!!
BTELL67 is offline
post #4 of 9 (permalink) Old May 27th, 12, 12:31 PM
Brent
67Rally's Avatar
Thanks Rally,
Can you get it with a little less backspace? I think 5 or 5.25 would probably work, or you could get a spacer with the 5.5 if they don't fit.
Like I said, mine don't have any room left to the inside, but I know some people have run 18.9.5's on their cars. How much of a drop do you have if any?
67Rally is offline
post #5 of 9 (permalink) Old May 27th, 12, 01:12 PM Thread Starter
BARTELL
No drop. Can get 5" or 5/5" BS only.
BTELL67 is offline
post #6 of 9 (permalink) Old May 27th, 12, 04:27 PM
I'd get the 5.5 BS and use a spacer as suggested. Buy a quality billet spacer if you go that route.
Mike68RS is offline
post #7 of 9 (permalink) Old May 27th, 12, 09:23 PM Thread Starter
BARTELL
Wil I have to roll my fenders though?
BTELL67 is offline
post #8 of 9 (permalink) Old May 28th, 12, 05:31 AM
Brent
67Rally's Avatar
No, you shouldn't have to roll your fender. The 5.5 BS will set the wheel in closer to the wheel well. It will either be very close or it will rub. If you use a spacer, it will push it back out towards the fender, but you should have plenty of room on the fender side.
275's will fit, especially with no drop. I'd install the wheels, the decide on how much of a spacer, if any, you need.
67Rally is offline
post #9 of 9 (permalink) Old May 28th, 12, 05:58 PM Thread Starter
BARTELL
I ordered the coy 18x8. They said 18x9.5 will rub and they won't take back.
BTELL67 is offline
