CenterLine Convo pro Shank problem - Team Camaro Tech
post #1 of 1 (permalink) Old May 28th, 12, 02:12 PM Thread Starter
Kill
Hi,
I bought front and rear Centerline Convo pro wheels with shank lug nut seat style and centerline lug shank style nuts(1/2- 20 RH).
so I thought that nuts will center the wheel but the lug nut diameter is much smaller then the hole.
I guess that means that shank style wheels needs to be centered by axle or front hub and I need to use hubcentric rings. Am I right?
That sucks cause wilwood front brake kits doesn't have provision for hubcentric.
Maybe someone could explain how can I solve this problem?
I'm thinking about to buy bigger diameter shank lug nuts and make it the same diameter as the holes on the wheel by lathe.
scratched is offline
